Old 08-11-2008, 05:53 PM
"Puddles the Pontiac" "Puddles the Pontiac" is offline
Send a message via Yahoo to "Puddles the Pontiac"
Unhappy Big timing issues, I need help BAD!
its been a while since i have posted here, i have been in the world of late model performance for a while. i have recently built a new motor for my '65 Lemans. specs are as follows ;
463 with eagle/scat/SRP rotator.
6x-4 heads w/heavy porting and 1.77ex valve (no numbers but professional work was done)
1.5 JBP roller rockers/pushrods
edelbrock T2 intake
holley 750hp carb
comp cams solid flat tappet custom grind.
lift .558i .580e
dur. @ .050- 260i 268e
110lsa
pertronix hei triggered by Mallory hyfire VI #685
module bypassed.
now that i have that out of the way, i built this motor to to give me high 11sec times and to be used w/ nitrous (i have a cheater kit). and at some point i will be adding turbos.after break in i gave this engine a quick "tune" by ear. i set the timing where the engine liked it and started good, set the idle mixture to the highest rpm. jetted by plug reading after a wfo pass down the road. now the engine barks when i rev it and sounds pretty good... in park. i take it out on the road and i have this frustrating miss. not a back fire or pop but a constant miss. here is an example in typed form if i may...
mmmmmmptmmmmmptmmptmmmmmptmmmmmptmmmm. at cruising speed. and i feel i am missing alot of power. i have changed and tested the coil, pickup coil, module, volts going in, alternator, plug wires. checked cam placement and valve lash as well. i feel this is electrical because i noticed the miss on the timing light while bringing the revs up in park. i installed the mallory unit hoping bypassing the module (hei distributor) and giving the coil a little more push would help things. i gained some power but still had the miss. now, here is another odd symptom, after resetting the distributor by putting the engine TDC on #1 and setting the timing to where it would start easy and idle strong, i checked the initial timing. i was at 50* of advance! i brought it back to 16* and that killed the engine. when i tried to start it it would pop a few through the carb and want to start. but wouldn't. 30* did okay but it wanted 50. if i went past 50 it went into a "blower surge" sounding idle. so i take off the cap, put the engine back TDC on #1, make sure #1 cap terminal matches the rotor, put the cap back on and fire it off. timing is at 30*. so i say to myself "fine, this $400 digital snap-on timing light is screwing with me". so i assume the light is off 30* and put the timing at 45*(assuming its really 15*). the engine likes it. so now i check the mech. advance. i go from 1000rpm to 1500 and the timing advances 10*. odd, i have the stiff springs on the advance weights but okay. i rev up to 2000 and the timing marks go crazy. they did this with the light springs too. oh and the miss is still there. so now i cant set my timing past 2000rpm. and as the engine gets warmer the miss is more pronounced.
so to put this in a nut shell,
my engine wants 50* of initial advance. it has an irregular but constant miss that shows up with the timing light. i cant set timing past 2000rpm. it is low on power. idle gets weak after warmup. and another symptom i noticed is, i can't get this thing to detonate on 93 octane. it was easy to do with the 290b-6 cam, but this one just wont do it.
notes of interest,
the only things distributor wise i didn't change was cap, rotor, and bushing. they all checked out good. as far as mechanically and visually. and the cam was installed straight up (same way i did with the 290b-6 which made alot more steam) crank dot at 12 o'clock and cam at 6 o'clock firing off cylinder #6.
guys, i am out of ideas and pretty down about the whole thing. i have been without this car for 2years. i feel i am a fair tuner but this has got me stumped. please help
Old enough to know better, but still too young to care.
Old 08-11-2008, 06:35 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Safe bet that the explanation for lost power is the reduction of cylinder pressure from the later IC event,coupled with the loss of some overlap from the wider LSA and not adding enough duration to make up for that loss of exhaust scavenging due to OL.
OE/ported pontiac iron heads love overlap in race engines,it helps make up for the weaker ports,as long as the exhaust is up to the task as well.
The reduction of cylinder pressure explains the reduced abillity to detonate.
The loss of overlap also means the VE likely dropped some too when the scavenging was reduced,so the cylinder is'nt filling as well in addition to the later IC event trapping less charge.
Installing the new cam striaght up just compounds the whole deal.
Was the new cam degreed when installed?
What are the advertised specs for that cam?
As for the igntion,my advice is to lock out the advance mechanism and phase the rotor and see how it responds,odds are that will be help a lot,and if you want a curve after that,run an electronic ignition curve box or such.
I would try advancing the cam to a 104°ish ICL and try some 1.65 ratio rockers on it,and run the lash as tight as you feel comfortable running it.
This space for rent...
In the meantime,check out the cars HERE.
Old 08-11-2008, 08:05 PM
as far as the cam goes, i had always thought the wider lsa cams had more cylinder pressure because of the lack of overlap bleeding off cylinder pressure. i went with this cam to be more nitrous friendly. i was talking to Jim Butler and we came up with this grind and when i ran it on Desktop dyno this cam actually out performed the 290b-6 by about 10hp peak and anywhere from 5-15 through out the curve. but i do put too much trust in the program. i need to study hard facts better i guess. i swapped distributors to see if there may have been advance issues but either one did the same. i will try locking out the advance. i just have never seen an engine prefer 50 degrees like this.
Old 08-11-2008, 09:39 PM
i am not seeing the advertised specs on this cam but [email protected] reads 289i 297e
valve timing is open int. 24 btdc close int. 56 abdc
open exh. 68 bbdc close exh. 20 atdc
specs are for cam installed on 106.0 icl
4 degrees advance ground in from factory.
does anyone else think i made a bad choice on this cam? and what role is this playing with my ignition timing if any? i swear it feels like i am learning this stuff all over again.
Old 08-11-2008, 09:51 PM
440GP69's Avatar
440GP69 440GP69 is offline
289-297 @ .020 is your advertised dur, thats a fairly large cam, 290B6 would outrun it with the other parts and setup you have now IMHO, Is it possible your ballancer shell has moved at all?, is the dist in right??, is it missing like a secondary ignition missfire or is it popping back through the intake?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 08-11-2008, 11:00 PM
i checked the balancer and it hasn't moved. it is a romac unit with marks to show if there is any movement. and as far as i know the distributor is in right. thats why i thought my timing light was going bad. with the rotor lined up to the #1 terminal in the cap, and #1 cylinder on TDC, it shows up as 30degrees advanced using the light.
Old 08-11-2008, 11:30 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Maybe borrow a new gun to make sure but if you're readings are correct you should only need 16 degrees initial and 20 mechanical as a good base ( vacuum unplugged ).
The car should run with 16 degrees unless you set up the idle for the crazy initial timing and the carb screw is out way too far.
Ideally you'd want 36 total and 48 cruise with the vacuum advance on.
Springs can cause a bounce on the gun if they don't seat properly.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 08-11-2008, 11:35 PM
Please folks,stop repeating this gem of information,it is not remotely accurate,overlap has nothing to do with cylinder pressure,not in the practical sense of this stuff.
Overlap happens at the end of the exhaust stroke,and the begining of the intake stroke,nowhere near the compression stroke.
The only events that significantly matter to the engine in terms of cylinder pressure is the intake closing,and possibly the exhaust opening events.
The only way overlap affects cylinder pressure is by influencing the VE and helping the engine get a dense intake charge to trap when the intake valve closes,that is the effect called "exhaust scavenging".
But that happens mostly at higher RPM's,not so much at lower RPM's.
And besides,speaking of overlap independantly of duration,LSA,and the actual valve events would be a complete waste of time for the most part.
A fella can have a ton of overlap and still crank out significant cylinder pressure numbers.
And he can do that with either a narrow or a wide LSA if he knows what he's doing.
Especially when taken in context with the given static compression ratio of the engine in question...
Now some honest food for thought.
New cam:Custom;
Spec = in/ex
Adv. dur. ~ 289°/297°
Dur. @ .050" ~ 260°/268°
Lift ~ who really cares...
LSA ~ 110° ICL ~ 106° ECL ~ 114°
Events:Seat (.020");
IO = 38.5° BTDC EO = 82.5° BBDC
IC = 70.5° ABDC EC = 34.5° ATDC
O/L = 73°
Events:@ .050"
IO = 24° BTDC EO = 68° BBDC
IC = 56° ABDC EC = 20° ATDC
O/L @ .050" = 44°
Now the 290b6:
Spec = intake/exhaust
Adv.Dur. = 290°/304°
Dur. @ .050" = 255°/266°
Lobe lift = .360"/.356" Rec.lash = .026"/.028"
LSA = 106° ICL = 106° ECL = 106°
Seat events:
IO = 39° BTDC ~ EO = 78° BBDC
IC = 71° ABDC ~ EC = 46° ATDC
Total O/L = 85°
.050" events:
IO = 21.5° BTDC ~ EO = 59° BBDC
IC = 53.5° ABDC ~ EC = 27° ATDC
O/L @ .050" = 48.5°
The new cam is not what I consider "bigger" than the 290b6.
Now,here's the clues,the intake events are'nt a whole lot different if indeed it did get installed @ the 106° ICL,that is in spite of the added .050" duration,that's all because of the similarity in the seat durations between the two cams,but you definitely lost some overlap everywhere,and honestly that's just what a fella who's gonna use spray normally wants to do,but that's also gonna make it seem a bit "sluggish" on the motor alone,especially if it is/was slightly overcammed to begin with or such.
By widening the LSA you effectively gave the exhaust lobe more time to do it's job.
You do so at the expense of the intake side,and at the expense of the exhaust scavenging when running NA,open the exhaust earlier it's gotta close earlier too for a given duration..
By "adding exhaust" to the cam you shoved the power curve upwards slightly,this also happens when you increase the intake/exhaust split as SOP.
So what happened,while you made the intakes lobes seem "smaller" for that given cam,so understand what does'nt make it into the engine to begin with,really cant be compressed to make that power later on,ie: if the intake side cant feed the HP,the exhaust side wont make that situation any better.
That's why nitrous and boost are generally less dependant on overlap,they help feed the intake side copious amounts of intake charge!
But in a NA combo,barring a restrictive exhaust system,that extra exhaust scavenging really helps get the intake charge moving in the right direction.
More charge,more power,it's as simple as that.
With big flow heads,and lots of cubes you dont need the scavenging nearly as much as you do with restrictive heads and such,it's almost like boost or juice in the most basic sense of all this.
Like I said in my first post,I would try advancing the cam to 102° to 104° ICL,and understand that absolutely all cams of this sort need to be degreed when installed,I simply cannot stress this strongly enough!
I would do that and as I said earlier maybe try adding higher ratio rockers (at least to the intake side) and try to tighten up the lash,these changes all should add back some of what was "lost" by widening the LSA and not going adding more seat duration,and that should hopefully help make similar NA power as the 290b6 made.
If it slows it down,then I dunno what to tell you,likely something else is amiss,as that should add power to that combo while trying to bring the power curve back down a few hundred RPMs or so at the same time.
BTW,I did'nt say I dont like this new cam,I just said it gave up some in the NA department,,,myself,,,I would have just sprayed the 290b6 and not lost a moments sleep over that deal...
I also think the car should have run a little better with the 290b6 combo,but you did'nt really give a bunch of info on that deal,please tell us more about the whole combo,what gears,convertor,tires,exhaust system,fuel system,that sorta stuff...
Was the intake port matched?
Tried any spacers or such?
The more you tell us the better!
Old 08-11-2008, 11:39 PM
As for the timing light deal,I dont use the high zoot digital/dialback deals,they just dont work reliably with all ignitions,I use a plain craftsman inductive light,and it has never failed me,it's the KISS method.
I just mark the balancers to find my initial & total timing,,,I hardly ever hafta use the TDC mark on mine at all...
Old 08-12-2008, 12:40 AM
i went to the new timing light 'cause my 43 year old inductive finally quit. but now i am comfy not trusting the dial back. and i do not believe what it is telling me. but i will be locking out the advance.
as for the cam, perhaps na i would be happier with the 290b-6. i got the cam i have now because this was going to be a nitrous engine. then i am going to try some "industrial equipment" turbos and see what kind of mess i can make of things. i do put some faith in the desktop dyno program and it showed this cam to be an improvment, not so much in overall power, but in VE. 88% for the 290b-6 and 95% for the custom at about 5500rpm. i'll admit ignorance as far as cam timing goes and as for why i do not degree a cam like i should. my feeling is (still declaring ignorance) if i install this cam by the marks on the sprockets, and with the 4 degrees built in, that would put me at 106 icl. any little adjustments either way would net me a negligible amount of power for a weekend bruiser/weekday cruiser. i mean i am looking for tenths, not hundreths, of a second at the track right? hence the reason i got nitrous and want turbos, and i have this unbelievable frustration of not being able to have a good set of aftermarket heads. i guess nobody has really explained the benefits as to why i should degree the cam. they all just say i need to. when i say why, i get, just to be sure. of what? nobody has explained it to me. i guess if someone said i was leaving about 25hp or 30ftlbs on the table i would be more apt to degree my cam.
oh, and this miss is still nagging me too.
Old 08-12-2008, 12:53 AM
oh, for the combo. well you know the engine, everything behind it...
standard sfi flexplate, 28-3200 stall converter, th400, stock rear w/3.23 gear. i know the gear is tall, but a 9" or an 8.5 will replace it. as soon as i settle on one. but with all this torque, i might as well use it to turn a tall gear right?
the car is a '65 LeMans, 3550lbs with me in it. Mallory's 685 does all the lighting and de-lighting of the plugs (except for that **** miss). shifting is done at 6000rpm. no times yet, the engine is barely a month old and i want it tuned in before i go to the track. tires are 295-50's. nothing fancy, dont have slicks yet.
fuel system is holley blue, sucking and pushing through -8an line regulated at 7.5 lbs. -6 to each carb bowl. fuel cell in trunk. vacuum gage crapped out so i cant say where i am at exactly with the carb. but my PV is a 6.5 and i need to get back to my 4.5 and go bigger with the pump nozzles. idle mixture is close. jetting is close (no good runs with this miss). fuel level set to the bottom of the sight plug.
Old 08-12-2008, 08:11 AM
Geoff Geoff is offline
Constant miss at cruising speed. Are you SURE you haven't wiped a lobe? The symptoms sure sound like it. What brand lifters were they? I have sets of Comp Cams 'premium' lifters, Crower & lifters from JBP all now performing paper weight duty, having wiped after correct break in procedure, correct oil etc. All were solid lifters.
Old 08-12-2008, 08:48 AM
wrench's Avatar
wrench wrench is offline
My Snap-on dial timing light did the same thing to me. Setting the timing with this light would not even let the car run?? After borrowing a light and setting the timing correctly, my Snap-on light read something like 80 degrees advanced at idle. Maybe your driveability issue is caused by severely retarded timing? I was running a MSD 6AL when I had this issue. A tech that works for me also had this issue. He had the timing light pick up on cylinder #2 instead of one, lol.
Old 08-12-2008, 12:56 PM
Geoff, i had that happen as well. they are comp lifters that came with the cam. with break in lube (from comp). i run Rotella T oil. and checked the lift to make sure a lobe didnt get wiped out. the miss itself is irregular, but its constantly happening. i also noticed the miss with the timing lights light. leading me to think it is electrical. btw, i will be using a different light to set timing. thank you for the responses so far.
Old 08-15-2008, 10:26 PM
well, after replacing the cap and rotor i managed to get the miss taken care of. now i am onto rethinking my cam. i am going to take some of 'chiefs advice, run it down the strip and see where it is really lacking. if all else fails, i will order another 290b-6. does anyone see any big issues with my combo as it stands? what should this run? i hate that my '97 LT1 trans am feels stronger then my '65 Lemans with a 455.
Old 08-15-2008, 11:10 PM
Dont changes cams till you get a chance to spray it.
Like I said,it may be just the ticket for that use.
I was just saying it's not odd that it felt a little soft,especially if it has'nt had a bunch of tuning time on it.
Easiest this to do is run some lash loops,tighten up the intake lash and see what happens,and go back on the intakes and do just the exhausts,then try tightening up both together,lots can be learned just by playing with the lash.
Then you experiment with the installed centerlines and rocker ratios,that's the whole beauty of solid cams,they are they're own tuning aid.
Only after exhausting all those avenues,should another cam choice be considered.
It's long tedious process,but the results often speak volumes about what the combo needs for improvement.
Did you ever get the timing deal figured out???
HTH.
Old 08-16-2008, 12:51 AM
thanks for the info, as far as the timing, i really dunno. i dont trust my digital light and cant find anyone with an inductive light. i am going off of how the engine cranks and runs. same with the carb. i am setting idle mixture off of rpm, power valve size by feel and jetting from plug reading. the engine revs like a monster and feels good all around untill i get on the road. it makes alot of noise but the punch just isnt there. even above 4000 i get nothing. it feels like it did when i had messed up installing my last cam. i found i had installed it (the previous cam) wrong using a 9 keyway crank sprocket. after lining it up the right way, it became a monster. but i have checked this cam and it is right (as far as installing straight up). and another issue i am noticing is it is losing its tune when it gets warm. i have a whole weekend to keep on this thing. again thanks for the help.
Old 09-06-2009, 06:05 PM
well, its been nearly a year now. and boy do i feel silly. my lack of power came from bent valves. yup, i managed to install the pistons with the valve reliefs down. lack of experience for sure, but wait, the rods were positioned correctly on the crank. ah, the machine shop installed the rods wrong on the pistons. i did check for p to v clearance, but failed to do so when i switched to 1.65 rocker from 1.5. that was just enough to bring piston into contact with valve. lesson learned for me and the machine shop. i did swap back to the 290b-6. and am pretty happy with it. i installed it straight up to aid with running on pump gas. it worked. but wait theres more...
my miss is still there, for the love of god it is still there! not to mention, my new found power seems to be eating up my trans. guess i will be learning how to rebuild a th400 soon. and i think i will have to just try a new distributor. anyway, live and learn.
Old 09-06-2009, 09:53 PM
Sun Tuned Sun Tuned is offline
Lots of probables here, one for certain.
Go to Sears and buy the 49.99 timing light they have... will be chrome, nothing more than a straight blink light. Never drop the inductive pickup for it and you'll be golden. HEI's do not like the dial back lights at all. I understand the Snap-On light runs about 500.00 if it's the digital job... but guess what??? HEI no likey, haven't seen one yet that was accurate on one. Not knocking it just need to spend 50.00 on a good one and no more problems there.
Recheck the timing deal then get back to us.
Old 09-07-2009, 03:00 PM
silver68's Avatar
silver68 silver68 is offline
I don't think you mentioned what static compression the engine has. If you don't know how far down in the bore the piston is at TDC, how many cc's the combustion chambers are, and the compressed thickness of the head gasket, you will only be making a wild guess as to what the compression is (and probably be wrong). For the cam you have you will need 11 to 1 for it run optimumly. That is my opinion and I recommend contacting the cam grinder to be sure. I can tell you for sure you have nowhere near enough converter or gearing, 4000 flash stall and 4.10 gears minimum are what that cam wants, again I repeat minimum. A big cam in a mismatched combination is the number 1 reason muscle cars lose a race to a turbo import car. If you do have enough compression for this cam, adding turbos to this engine will bring immediate fatal results. No problem with NO2, but forgret about boost. Optimimize your engine, driveline, suspension, and tires, and this car should be quick enough with a 150 hp shot of nitrous to require major safety upgrades to race at most tracks. Your misfire at cruising speed (if your timing is set properly) I can almost guarantee, is due to a lean mixture of the idle transition circuit. This can not be adjusted with the idle mixture screws or changing the jets. There is no reason not to have a wideband O2 sensor in any true performance car. Also, if you are reading plugs and using any of the charts in commonly found in repair manuals that show horribly carboned up plugs, you are not reading them properly. racingsecrets.com has a great video and plug reading light for sale. As far as tuning out the miss in your engine, the general tuning forum on innovate motorsports website, will blow your mind with the references and advice available and I recommend everyone with a performance car to visit there. I thought I was real good with carbs until I got a wideband setup and realized how wrong I was and how much I had to learn. However, learning to properly read plugs is still critical.
