Old 08-24-2008, 07:12 PM
PonchoV8 PonchoV8 is offline
Default How difficult is it to install the wheel fairings on a 79-81?
I know someone that has a rear one to remove and install. He knows nothing about F-bodies and I've never done it.
Old 08-24-2008, 07:19 PM
2manyT/A'S's Avatar
If you are referring to the wheel opening spoilers that mount in
front of each wheel on the fender,it's pretty much a "no brainer".
Just do a layout,drill some holes & bolt them up.
For the rears,you will need to remove the black rectangular airvents in the door jamb above striker.
Old 08-25-2008, 02:10 AM
"QUICK-SILVER" "QUICK-SILVER" is online now
R&R
Exposed screws around fenderwell lip and under rocker.
Stick your hand through the air vent hole, in door jamb, to access hidden studs with nuts.
You might want to put a layer of masking tape around the edge of the air vent hole, before you stick your hand through, saves band-aids later.
