Old 09-05-2008, 11:06 PM
superblue72 superblue72 is offline
Default Performance Radiators
Any out there that is compatible with the 71-72 venturas?
Old 09-06-2008, 07:49 AM
ponjohn's Avatar
ponjohn ponjohn is offline
I run an al. griffin. I have no idea if it wider than stock, but it is thick. There is a sticker on it, I'll see if the p/n is on that.
Old 09-06-2008, 08:40 AM
BILTIT's Avatar
BILTIT BILTIT is offline
Are they the same as a 73-74? I run an aluminum off ebay, works well so far.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 09-07-2008, 11:06 AM
ponjohn's Avatar
no p/n just phone # for Griffin.
Old 09-09-2008, 10:45 AM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Besides 2 different stock radiators, I've had two different aluminum radiators in my car.
The current set up is using a 22x19" GM style universal with a single 1560 cfm S blade fan pushing and Mezeire water pump. I haven't noticed temps any higher then 170 after back to back passes and a little street driving, I have the grill plugged as well.
I did have to make my own mounting brackets for this radiator.
Before I had a 31"x19 universal with the same fan pulling but had a stock replacement water pump and the grills open. Temps stay around 160 constantly after I figured out the thermostat opening size. I had 3 thermostats stick so now I just run a restricter. Mounting was easier as I could use the stock mounting configuration.
I believe the stock radiator dimension is 26x19.
HTH
Old 09-09-2008, 06:40 PM
ponjohn's Avatar
I measured my radiator. Is is 3" thick and 30 1/2" wide.
Old 09-19-2008, 12:34 AM
i am thinking about putting a 3 row in my 6 cyl. is that overkill?
