Old 09-06-2008, 10:28 AM
Walleye Brat Walleye Brat is offline
Default Any tips on pulling the starter?
On our '68 GTO. It seems stuck up there between the frame and the oil pan and all kinds of things. Any tricks??
Old 09-07-2008, 01:50 AM
cuz68's Avatar
cuz68 cuz68 is offline
Wink
Take the rear bracket off of it first,Take the 2 bolts out of it and unhook the wires it will drop down.
Old 09-07-2008, 09:28 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
or slide out to the front possibly
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 09-07-2008, 10:31 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Remember the starter is very heavy for its size. Don't forget to disconnect the wires. Keep track of the shims too!
Jon
1968 GTO with SC&C Suspension
Old 09-07-2008, 07:29 PM
Pound for pound one of the worst ``on your back`` jobs on a poncho.
Be very careful that the wires end up clear of the exhaust manifold when putting it back.
Old 09-08-2008, 07:14 AM
I remember when I had my first GTO back in 1982. It used to go through at least 2 remanufactured starters a year and was a pain to change.
I seem to recall having to loosen the exhaust downpipe at the manifold every time I did it. A real pain.
Old 09-08-2008, 03:37 PM
newtoGTO newtoGTO is offline
Just did this 2 weeks ago. A task you don't forget very quickly.
As Greg said disconnect the left exhaust pipe from the exhaust manifold to give a bit more room. I disconnected the wiring prior to dropping the starter. There are three bolts, two towards the rear and one on the front support bracket (sometimes this one is missing).
Used a jack to help with support when removing and reinstalling.
As said keep the same number of shims. The factory determined shims by "sound" but you could use a paperclip to measure the gap if you wanted to.
Torque for the rear bolts is 20ft-lb to 30ft-lb for the reinstall. Did mine at 25ft-lb.
Just a side recommendation. Look at your positive battery cable and deceide if it is good or not as this is the time to replace it. I'm a firm believer that many of the "hot start" problems I read about are related closely to a poor or inadequate electrical connection (pos and neg).
