Old 09-22-2008, 09:03 AM
jlwdvm's Avatar
jlwdvm jlwdvm is offline
Default Pics of z-bar bracket and linkage
Anybody have picutres of the z-bar bracket and linkages already installed in the car? Trying to get a mystery solved. I'm wondering if my z-bar bracket needs to be moved.
Old 09-22-2008, 10:59 AM
blackbird455's Avatar
blackbird455 blackbird455 is offline
Send a message via ICQ to blackbird455
Default pictures
I took a few quick ones not the best . I hope they help
Name:	z bar 002.jpg
ID:	143620   Click image for larger version
Name:	z bar 004.jpg
ID:	143622   Click image for larger version
Name:	z bar 007.jpg
Have some fun while ya still can !
Old 09-22-2008, 01:11 PM
jlwdvm's Avatar
Thanks for the pictures Black Bird. It looks like Our subframes are the same in reguards to the bracket mount holes (one hole in front of bracket not used and the top one behind the inner fender). Any chance you could measure your countershaft length so I can see if mine is the same? When you look up at the countershaft (or down I guess) is it perfectly square to the block? Thanks again!
Old 10-06-2008, 08:48 PM
Bum67 Bum67 is offline
Default Z-bar frame bracket
The z-bar bracket on a 67 Firebird is different than a 68 or 69. I bought a repo that was suppose to fit 67 - 69 but it did not line up to my 3 bolt holes. to make it fit and line up correctly I was going to have to drill new holes. I started looking at my subframe ( factory auto car )and the three factory holes were all ready tapped. I didn't want to drill new ones and I thought the factory did this for a reason. I started looking at this bracket on 67 cars at car shows and noticed the shape and hole location was different on the 67 cars. I bought a 67 400 4spd parts car and removed its bracket. It bolted up perfectly. By using the 67 bracket my z-bar lined up and worked great. If you need a picture send me a PM. The 67 is more rectangular the 68-69 looks like a boot shape
Old 10-06-2008, 09:02 PM
