Old 09-26-2008, 06:07 PM
gunmetalgray67's Avatar
gunmetalgray67 gunmetalgray67 is offline
Question BHJ balancers
Anyone have any problems with a BHJ balancer? I just bought one for my 400/467 stroker build because my engine builder recommended it over the cheaper models (Professional Products, Summit, etc) and I didn't want to mess with redrilling pulleys for an ATI. I saw some bad comments about BHJs on another Pontiac forum.
Old 09-26-2008, 06:38 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Mine looked like it was wobbling on the crank. Turns out it slipped a few degrees. They can be rebuilt and re certified for around $75.
Old 09-26-2008, 06:41 PM
TIN TIGR TIN TIGR is offline
yep, they are junk..i'll give ya 100 dollars less than what ya paid for it, you pay shipping
nothing wrong with them, seen them on engines for years..i even have a few..the fluidampr is the funny one..if fluid goes wacko the motor literally blows the mains caps right off and shatters forged cranks..
Old 09-26-2008, 06:45 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
I ran one I got used on my boat for a few years (455P). It spent its whole time spinning at 35-5200 RPMS and never had a problem with it. I will be getting another one for my upcoming build.
Old 09-26-2008, 07:27 PM
punisher#1's Avatar
punisher#1 punisher#1 is offline
i have had 3 of them spin the weight on the hub. they took care of everyone of them but i would recommend putting witness marks on them and looking at them often.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 09-26-2008, 08:02 PM
440GP69's Avatar
440GP69 440GP69 is offline
Another good one is the Pro/Race or Summit SFI Damper, has the 4-bolt pattern, The Outer Hub and inner hub are splined so no issues there and no bolts to fall out, These are made by an ex Top Fuel Drag Racer and are really good quality but without the Super high cost, Summit has them for 240$ One going on my 535, It Looks close to stock but all billit Similer to a Romac But Less $
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 09-28-2008, 10:41 AM
PONTIAC DUDE's Avatar
Wink
I don't recommend BHJ after running them and having issues. The ONLY balancer i have ever had an issie with. Other then a stock balancer.
Don't have issues with PP balancers. So far. Maybe you need a builder with more experience?
Old 09-28-2008, 11:33 AM
we all have different experiences..i would rather try the cheap hub if its works well..
Old 09-28-2008, 11:39 AM
Mr Twister's Avatar
Sounds like I was Lucky on mine. What is a PP Balancer?
Old 09-28-2008, 11:44 AM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
My P P balancer spun off the hub and took out the timing cover. I went with a Romac.
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 09-28-2008, 12:02 PM
Old Goat Racer's Avatar
My BHJ cracked at the hub & slipped 10 degrees. $225 to get it rebuilt. I bought a Summit SFI for $229 instead.
Everybody knows somthin.
Nobody knows everything !
Old 09-28-2008, 02:31 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Every PP balancer I have seen run[5 so far] has had issues right off the bat. Slipped outer rings, pulley spacing wrong, name plate screws coming out[even with lock tight], shaking engines. One Pontiac we dynoed shook so bad you could feel it in the floor. Shut it down and the balancer was smoking. All the paint burned off, outer ring loose. The customer had a spare BHJ balancer we put on and the engine ran smooth with no problems and is still running. This Pontiac in question was built by another Pontiac builder on these forums who installed the PP balancer. I would not use them for anything personally.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 09-28-2008, 02:41 PM
440GP69's Avatar
The PP's are junk IMO, Bolts coming out slipping hubs no thanks, The summit sfi or Pro Race is the way to go IMO or ATI if ya have the funds
Old 09-28-2008, 04:58 PM
Thumbs up
Damn. Been lucky so far with a PP on my 535. The BHJ I had slipped the outer ring and really thru me into a timing issue as i changed the ingnition box and after a month of buying another timing light without an advance and checking this and try that pulled the BHJ and found the issue. Never had a balancer other then factory ever slip before. Hummmmmm.
Only issue i found was with the early PP and timing marks. And one that had course threads in it. But then again like 99% of everything else Made In China. LOL.
Did have a sbc Pro race SFI shatter on a roundy round engine after a year of use.. Wasn't there so can;'t really state all the facts. But all in all Pro Race might be the better of the easier on the wallet balancers out there.
Got a few on BBC's over the years and making hp without issues.
Old 09-28-2008, 07:35 PM
greggutknecht greggutknecht is offline
BHJ told me the outer ring will spin if your spraying a serious amount of n2o.Greg
Old 09-28-2008, 08:55 PM
Talking
me? Serious amounts of Nitrous ?????????? bwahahahahahahahaha. Interesting thou.
Old 09-29-2008, 04:08 AM
jm455ho's Avatar
jm455ho jm455ho is offline
TIN TIGR, what do you mean about fluid going wacko in Fluidampr? I bought a Fluidampr when there wasn't much choice for Pontiacs years ago and never anticipated any problem. The damper is one solid piece with fluid inside. Not much to go wrong IMO.
www.hobracing.com
Old 09-29-2008, 10:29 AM
on the fluid dampr..it was on a nice 454 chevy..the motor ran well, but died..owner was an animal, never warmed it up, just start it and hit 6k plus..it finally blew the distributor out of the engine..upon teardown the caps were walking, and the crank was cracked in 6 spots..i know he ran cheap gas in it to amaze his pals, but the bearings showed no signs of scuffing or detonation..apparently, from other boards, and speaking to some folks, the fluidampr needs a couple minutes to warm up and get fluid moving...if ya wing it right off, the fluid can be stuck in one spot and throw balance waaaay off..this is what i was told, and from what i found, seemed plausible..
and i have no issues with bhj..what kind of dampr does butler sell?
Old 09-29-2008, 03:47 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My PP is loosing the degree marks after maybe 30 street miles and 8 passes over 3 years.
Skip Fix
