Old 09-30-2008, 06:10 PM
bren566's Avatar
bren566 bren566 is offline
Thumbs up 70 GTO exhaust manifold install
I tried a forum search, but didn't really find an answer. Is it necessary to remove the motor mounts when installing factory exhaust manifolds while motor is in vehicle? Thanks
Old 09-30-2008, 06:33 PM
getmygoat's Avatar
Default bolt
You'll certainly need to remove the main bolt and jack the engine up. Not a big deal.
You can likely get the manifold on without removing the mount entirely from the block.
