Old 10-02-2008, 08:50 AM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Default Glove Box Door 69 GTO
The plastic hinge strip on my glove box door broke completely in two. Is this part reproduced? If not, can I fix this with maybe a piano hinge or something similar?
Thanks, Bill
Old 10-02-2008, 12:48 PM
Ron Landis's Avatar
Smile I have...
an old door you can have if you think it will provide a remedy. Ron
Old 10-02-2008, 02:31 PM
paint guy paint guy is offline
I just fixed mine with a piano hinge,had to cut down one side of the hinge,and had to screw the hinge to the metal(inside)past of the door.can't tell from the outside,looks original until opened,(should even be tough to notice when opened)will never have to worry about it again.BTW,to the best of my knowledge,they are NOT being reproduced.Hope this helps.I also have another door with the hinge starting to break.
Old 10-02-2008, 02:44 PM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
They are not and an annoying part to start with. Poorly made when new too. Paint guys remedy sounds good.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
Old 10-02-2008, 02:49 PM
KO KO is offline
I have a black 69 glove box door if needed
1989 Automotive Hall of Fame Inductee
Old 10-04-2008, 09:36 AM
I have had 69 GTO's for a quarter century and ever since the beginning worried that that crummy hinge design would let go, for what it is worth, it has never happened to me and you are the first incidence of it I ever came across.
All that to say that there are lots of them outhere and they are not expensive enough to mess with a repair that will never look right when it comes to selling the car.
Old 10-05-2008, 09:42 PM
6T9GTO's Avatar
PM's sent to Ron and KO.
