Old 10-02-2008, 08:12 PM
y82ws6 y82ws6 is offline
Send a message via Yahoo to y82ws6
Default 2ND GEN 6 SPEED SWAP
Has anyone done this or know what it entales?Keisler has no kit for this,why is that?Thanks
Old 10-02-2008, 08:54 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
I know a friend of mine just put one in his '67. I haven't really had a chance to talk to him to get the details. I think he used a Tremec but I don't know for sure..
_____________________________
www.classicpontiacrescue.com
Old 10-03-2008, 07:42 AM
Wick's Avatar
Wick Wick is offline
I think Richmond makes one that is pretty much a bolt in. Look at Summit.
She woke up sunny side down and I was still thinking I was too proud to flip her over
Old 10-03-2008, 08:24 AM
Larry Navarro's Avatar
I thought Kiesler dealt with the tremec transmissions, not the Richmonds.
Old 10-03-2008, 12:28 PM
takid455 takid455 is offline
Send a message via AIM to takid455
I have swapped a t56 six speed into my 78 t/a. it can be done w/ no cutting. I have a x-member specifically designed for this swap. cost for the swap is between 1500-2k for parts not including the trans. you will need to modify a lakewood or stock bellhousing or get a mcleod one. you can reuse your stock clutch setup or switch to a hydraulic one. you will need a shorter driveshaft. you can have your tail housing modified to mechanical speedo or get a mechanical to electrical converter.
some basic pictures
Old 10-05-2008, 11:14 AM
crider crider is offline
Send a message via Yahoo to crider
I have a t-56 in my 71 also. It's not a very difficult swap. I made everything myself other than, the Mcleod bell housing adapter. It does wonders for the driveability and gas mileage. I'm getting 26-28 mpg with 3.90 gears
Old 10-05-2008, 03:38 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Thumbs up
some basic pictures
Very nice.
Old 10-05-2008, 08:09 PM
Cammer-6 Cammer-6 is offline
got any details on that crossmember?
Old 10-05-2008, 11:51 PM
wareagle - thanks for the complements
cammer - info on the x member
http://www.nastyz28.com/forum/showthread.php?t=115055
Old 10-06-2008, 02:58 PM
niceta's Avatar
niceta niceta is offline
I too am considering the swap to 5 Spd from Auto in my 73 T/A. I gave these guys a call and they seem very knowledgeable good to deal with. A buddy of mine just bought one of their kits for his chevelle and says it is a nice kit. The prices seem pretty reasonable. I think it was around $2600 for the TKO street kit. Depending on HP a better clutch may be required. The kit comes complete everything except pedals although they do sell a pedal kit as well. Hope this helps.
http://www.classicchevy5speed.com/El...81-Tremec.aspx
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes.
https://www.facebook.com/media/set/?...7567172&type=3
