Old 10-18-2008, 05:39 PM
Mr W72's Avatar
Mr W72 Mr W72 is offline
Default Firewall Markings
Ever wonder why you never see grease pencil markings on the firewall of original unrestored Norwood OH produced 1977 Firebirds? I carefully studied our very low-mile 1977 Trans Am survivor and have found that grease markings were written on the firewall. It is just they were applied on the red oxide primer then sprayed over by the thinly covered black paint used on the firewall. In the proper light I can faintly see 75 which is the color code for our car and is located on the upper passenger side of the firewall.
So those of you who are correctly restoring a 1977 Firebird, yes there were paint codes written on the firewall. They were, however covered over by a thin coating of black paint used on the firewall.
Not sure on 1978 and 1979 Norwood OH built cars but I would say the process would have been the same. I am not sure about Van Nuys built cars at this time.
John Witzke
POCI Tech Advisor
1977-79 W72 Performance Package Historian
Old 10-21-2008, 09:28 AM
formula400's Avatar
formula400 formula400 is offline
Yep your right..... 1979 T/A
Old 10-21-2008, 04:40 PM
David David is offline
Here's a couple of ones that I found.
This one is on my Atlantis Blue 400 4 speed TA. It matches up to the numbers on the build sheet.
This one if from a 79 400 4 speed TATA
David
__________________________________________________ ________________________
My 79 400 4 speed Formula
either get busy living or get busy dying
Old 10-27-2008, 11:20 PM
ScottD3 ScottD3 is offline
Here are some on my firewall
