BUTLER WIDEPORTS ARE HERE!
Just came ups today!
I took some pics,including ones showing the difference in port size when matched up to my old 300cfm edel intake gaskets. they are going on a 468ci(455). 11.2:1 comp for pump gas Along with the new combo is a custom gring fast ramp solid roller 272-280 dur@.050,.704 lift,110 ls degreed to 110. offset lifters and t&d shaft rocker system Port matched 4500 victor 1095 removable sleeve king demon.
9.81 at 139.89mph 3400lbs Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS! 370cfm butler eheads port matched victor 1095 king demon 4.30gear,th400 MICKEY THOMPSON DRAG RADIAL tire |
Car is almost done too,i have been working on painting it.
It needs to all come together for a nov.14th track rental! Finally,no more primer!!!!!!!!
I've got Butler wide ports on my 541. Great heads. Intake is from Jim Robertson and is a great piece as well.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
lookn great cant wait to hear the results.
heads and car look great! could you post the flow sheets? i have 318cfm elds. from butler and i am thinking of upgrading. thanks, brad.
1973 ventura pump gas street car -NA-10.68@126.6mph/ N2O-9.97@136.6, 3645# 1968 procharged firebird 5.66@123mph 1/8mile-F-2(22#boost), CSU E-85 carb, 477 IA2, 315cfm Butler E-heads, and factory suspension, 3580#. 939RWHP@25#boost thanks to Butler Performance, CSU carbs, and All Pontiac. |
The heads look real nice, also i really like that car, the paint and those wheels really set it off, nice work...
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
good luck with the new setup, the car is going to look sic all together painted with those wheels.. very nice
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
Very Nice work.
Will this still be a streetcar?
Mark |
Ports are huge. Real nice craftsmanship.
What do they flow? What lobe profile is the cam? John |
I hate you...
Very nice - makes my new 330cfm units from SD look like childs play.....
You suck, and I am jealous. Not necessarily in that order.
Looks great man, good luck!
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
Looks great, the car should run as good as it now looks. Good Job
WWW.GTOROADRACER.com |
Butler Widports are great heads.. you should make some good hp numbers with them..
good luck. BUTLER POWER!!
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Great looking Trans Am. Could you tell me what size tires you have on the rear and what the offset is on your wheels? I have a 78 Trans Am and am looking at the same wheels
I dont have flow sheets yet,they are sending it with intake. I will post it when i get it,prob by friday. They should be around 370cfm.
Yep,still a street car on pump gas.
That was one of the main goals,to keep it streetable.
Should flow around 370cfm,i will post flow sheet when i get it. The cam is a fast ramp solid roller. .440 lobe 272-280 dur @ .050 110 ls degreed to 110
15x10 with 5.5" backspace Tires are hoosier qtp's 28x13.50-15 which has an 11" tread and i measure it as a 13.25" section width. Only mod to get them to fit was to massage the seatbelt hump in the wheelwell.
Damn
nice frickin heads
nice frickin wheels nice frickin paint your car was an animal now its gonna be a beast! Right On !! Killer street car. Congrats.
"Chief" Knucklehead 462 E Heads Solid Roller 91 Octane Nash Stick |
