Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
Plumbing qeestions
Hi guys,
I'm replacing a hot water heater tomorrow at my rental property. A few questions. I have to at some point join galvinized with new copper.I noticed that everywhere else in the house that this was done they used a union that I'm not familiar with. Can't you screw a male copper fitting into a female galvinized joint? Is it possible/to code to hook up a short flexible gas line to connect the black pipe to the water heater? This would seem alot easier then to find black pipe the exact lenghts I need to hook the existing pipe to the new gas inlet on the water heater. Thanks,Drake
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
After doing searching on some plumbing forums,it appears that I do need a dielectric union to join galvinized to copper (or brass).
Looks like I can run up to 4' of flex gas line to the water heater also. I've never seen flex line run to a hot water heater in my life,but seems like it would make things a little easier for me.
How about this? "dielectric nipple"
. http://www.rd.com/familyhandyman/content/80124/ |
Thanks.
I have not seen one of those before. I'll have to see if they have something like that at the home center where I shop.
Should of asked before, why are you changing tank, Is it to old, leaking or just short of hot water? I ask because I almost changed mine 2 years ago because of short hot water only enough for one shower and it was the dip tube ($10) It is plastic and breaks down . Very easy to change!!
.http://home.howstuffworks.com/water-heater1.htm Letter L Last edited by Carl A; 10-26-2008 at 01:50 AM. |
Mine is leaking where it corroded around the water inlet on top.
You can easily install a dielectric union, which is what you need. When copper & galvanized are directly connected, pipes can corrode to the point of failure. I'm not convinced that the nipple will work as well. I have heard that a brass nipple can isolate the copper from the galvanized well enough to prevent pipe failure.
Alan Tomorrow is often the busiest day of the week. |
Had to ask, my dad had a rental prop at one time we learned to fix a lot of problems.
Yeah,it should be no big deal to put one of those unions in. It's just that when I went over to the house to look at the plumbing I had never seen one before because I never really had to deal with galvanized.
It sure helps to DIY or I could never keep a rental profitable. I only call in someone if I'm swamped at my job,or an emergency. Now if I could find an all night store for 3rd shifters like me. No sleep again tomorrow I guess. Thanks guys!
I recently had a copper water line start leaking at my rental house, which is 125 miles away. The leak was pretty bad when it was discovered by the tenant on a Sunday, so I had to get it stopped.
I went to the local Home Depot to get something to cap the line, and he recommended using something called Shark Bites. This is a special compression style fitting that can join copper pipes or PEX type pipes. I cut the bad section out and replaced it with a section of PEX tubing. It was quick, required no torch or heating, and did not leak. I also cut out a valve that began leaking and replaced it. They make a host of stuff that will mix with copper. Here's the link. http://www.pexsupply.com/CategoryPre...D=588&brandid= |
I had seen those talked about on a plumbing forum. I could not tell if they would be compatible with galvinized pipe though. Seems like they are compatible with PEX and copper line. I didn't see them at the first store I was at (which was out of dielectric 1/2" fittings),but I did see them at Home Depot. Problem is,at my local HD you can never find ANYBODY to talk to,so I just bought my dielectic fittings.
you need new flex lines for the water supply and hot water outlet which both do not need a dielectric fitting and a flex gas line. no big deal.
Generally you are not permitted to directly connect the plastic lines to the water heater. Most codes around here require a minimum 15" of copper before you connect a plastic material such as PEX or CPVC.
My money talks to me-it usually says goodbye! |
missed it, thought he was talking about metal to metal, no plastic or PEX involved.
