Old 10-26-2008, 11:10 AM
ebgto ebgto is offline
Default 4 bolt mains - dipstick - windage tray
Placing this under race, since I figured you guys with have more experience with 4 bolts. My builder is assembling a '68 400 for a stock GTO. Motor is just being built as an HO, with nice exhaust mainly for street and occasional strip use. The block already had after market 4 bolt mains installed. The factory windage tray will not fit on the mains and the 68 bottom dipstick tube appears to need to be bent to clear the main. Questions,
1.) Should I switch to the 72-77 lower tube with a bracket, if the windage tray cannot be used? I understand the lower tube needs something to keep it in place. Any other options?
2.) Is it worthwhile installing an after market windage tray (assuming original will not work)? Will it buy anything for street use with an automatic?
3.) Any other tips or advice on getting dipstick tube to clear the 4 bolt main?
Sorry about the basic question and thanks for your help!
'67 GTO Convertible - a couple extra HP, On the road!
'68 GTO Convertible - in frame off stage
'67 GTO Hdtp, HO 4 speed - next
Old 10-26-2008, 01:46 PM
shaker455's Avatar
shaker455 shaker455 is offline
I have used a stock tray many times on aftermarket (Pro-gram) caps & studs.
As long as you have holes drilled & tapped in the caps and no shims are nessary.
Try bolting it down and rotate the assembly and look for anything that may contact.
Also, you may have to bend the lower tube slightly.
Some aftermarket units that are stock replacement are a good idea as the factory units are thin and in some cases have fractured and broke while in service.
