Fuel Return Line
Do all 67 firebird 400s have a return line? I'm getting ready to place an order for all the fuel lines plus a new tank and I want to make sure I getr everything. I plan on using SS lines.
Any advice? |
Mine does, but I'm changing fuel pumps (putting in a Holly) and it doesn't have the provision for the return vapor line, so I'm going to cut the return line off at the frame and cap it off.
Can someone chime in on whether this is a good idea or not? Thanks.
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house... |
no need to cut any line if you dont want to use. theres a joint in it near the front of lower control arm. |
1) Never seen a fuel filter with a provision for the return line - you talking about the fuel pump? The stock one has it, not the Holly I used on my LeMans 2) That return line is rubbing on my Dougs Headers - that's why I want to remove it 3) I should probably post a picture so we're on the same page here
some fuel filters do have one inlet and two outlets: one to the carb, one to the return line. you can find them on the rack at any parts store. i think only the HO cars got the return line. i have a 400 that was originally a 350 w/o a return line and was contemplating adding one to help with vapor lock issues. if you have a return line, you will have a different fuel tank outlet.
John J. |
heres one thats NOS
68 Firebird 400HO / 4-Speed Coupe - Future Pure Stock Drag Racer 89 Firebird Formula - 305 TPI / 5-Speed Hardtop |
Seriously though - do I need the return line? It's rubbing on my headers.
If need be reroute it |
