Old 11-15-2008, 12:34 PM
2+2+3x2's Avatar
2+2+3x2 2+2+3x2 is offline
Default Throttle return spring bracket
I need the throttle return spring bracket that bolts down to the intake on the drivers side next to the rear carb of a '65 2+2 tri-power car, the spring attaches to it and then either goes forward to the center carb linkage or goes to the rear to the linkage at the firewall, I've seen it hooked either way, not sure which is correct. I'm told this same bracket is used on the 4-barrel car. Let me know if you have one.
Old 11-15-2008, 08:29 PM
GonicGM's Avatar
GonicGM GonicGM is offline
Have a throttle return spring bracket, not sure on year or application, will send image, PM me your email.
Gregg V.
Old 11-17-2008, 11:30 AM
2+2+3x2's Avatar
PM sent
