Old 11-18-2008, 09:05 PM
Axle07's Avatar
Axle07 Axle07 is offline
Default Carb question
I'm kinda new to my 77 T/A with the Quadrajet Rochester so I want to know how the choke works and how it effects the secondary linkage because mine isn't working right. My timing has been set right and the carburetor has been adjusted. I've done a lot to get this car on the road and this is the last thing keeping me back.
Thanks.
Old 11-18-2008, 10:23 PM
grandville455's Avatar
grandville455 grandville455 is offline
please take a pic of the carb and we could help u..and see if anything is wrong?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 11-19-2008, 06:07 AM
Kenth's Avatar
Kenth Kenth is offline
With cold engine put the pedal to the floor and release.
This will make the bimetal spring in choke hosing to close choke blade.
Start engine and the choke pull-off will open the chokeblade slightly to avoid load up, approximately .160 measured at rear edge of chokeblade and wall.
As engine gets hotter the bimetal in choke housing will let choke blade open fully due to hot air entering the choke housing thru the tube from intake.
The choke pull-off also controls the airvalves opening speed.
Old 11-19-2008, 09:22 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
And when the choke is on it blocks the opening of the secondaries until the engine is warmed up.
Pick up Doug Roe or Cliff Ruggles respective books and you will learn/know more about Q-Jets than most speed shops.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 11-19-2008, 10:16 PM
Axle07's Avatar
Know where I can get that book at? And I'll try to post some pics when I have something other than my phone to take them with, hopefully soon.
Thanks.
Old 11-19-2008, 10:19 PM
amazon.com should have it!...
Darby
