Old 11-23-2008, 09:59 AM
edolbud edolbud is offline
Default 66 Ralley Gauge Wiring HELP
Any Help out there I'm getting closer to finishing my 3 year restoration project on my 66 convertible and I'm trying to wire the dash back in I have a new harness with correct colors but I dont know what color wires go on the Tach also does the blinker light have a seperate connection? any input on any of the dash wiring would be a big help Thanks Tom
Old 11-23-2008, 11:27 AM
Jeff Hamlin's Avatar
Tach will be a single brown lead.
The Signal is fead by two leads, DK & Lt Blue.
What harness are you using?
PITA painless or an M&H plug & play?
Old 11-23-2008, 12:58 PM
Thanks I'll try that I'm not sure what brand I got it from Ames
Old 11-23-2008, 10:27 PM
1solidgto 1solidgto is offline
I am looking at my dash I have a new harness from Ames a M&H and I am wondering if you had all of the light sockets full I don't have one for the BRAKE lamp. I have rallly Gauges also.
Jon
Old 11-24-2008, 06:57 AM
Brake warning light was an option for 66'.
The factory put the hole & red lens in but you had to pay around $3 for the light itself.
Old 11-24-2008, 06:46 PM
Jeff Is it something I can add on or not?
Jon
Old 11-24-2008, 07:05 PM
I assume you have the intire 984702 option assembly so the brown lead plugs into the lower right of the fuse box and the black lead goes to the plunger (switch) mounted at the hand brake
Old 11-24-2008, 07:22 PM
There is a kit on ebay right now check this item # 130269360152 this what I have in my car and no I'm not the seller I just seen it there
