Old 11-26-2008, 01:31 PM
JACK_BURTON55's Avatar
JACK_BURTON55 JACK_BURTON55 is offline
Default 2.41 rear +TH350 = 75+mph??????
Is this even possible? i mean calculating in out, i could do 75mph at only 5477 rpm. This is insane, could the the TH350 even take it? the manual says to not go above 40mph in first gear.
http://www.chevellecd.com/66cd/tech/calc_rpm.htm
"Like i told my last wife, I said honey i never drive faster than I can see, besides that its all in the reflexes"
Old 11-26-2008, 01:45 PM
BVR421's Avatar
BVR421 BVR421 is offline
yes it is possible, no dont do it
the trans will take it but your 350 probably would do it one time only
Old 11-26-2008, 02:13 PM
69Customs's Avatar
69Customs 69Customs is offline
I run a 350 with 2800 summit cam and she runs up to 5640 all the time and there aint no more! Just flat lines.
Go for it!
Old 11-26-2008, 02:28 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
My first GTO had 2.72:1 gears in it. I think I used to shift out of first at about 55mph. It would bark the tires too. That car would scream on the highway. You can't be scared!
Old 11-26-2008, 04:04 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
All my cars have had 2.73 gears. When I raced I would shift first to second at 6000 rpm and go through the lights at 6000 rpm in second gear.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 11-26-2008, 05:16 PM
Half-Inch Stud's Avatar
I can only imagine the 2.41 (or sicker) Pinion head dancing around inside the housing, with the instant "seize the moment" lockup jam between the diff & case floor.
Old 11-26-2008, 05:44 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Don't do it. There's really no need to, even if you just want to see if it can be done.
Not to mention you do have losses not being factored in, which may make the RPMs higher at 75MPH than the calculated values.
Old 11-26-2008, 07:37 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
FWIW my TA with 2.56 rear gears and a TH 350 could do most of the Texas World Speedway road course in second- close to 90 mph. Did need third for the last curve onto the ovla's long straight. It also was barely in 3rd in the 1/4 with a fairly stock motor.
Skip Fix
Old 11-26-2008, 10:59 PM
lol this is interesting. I think its kinda funny, talk about tall gears, i dont think i would ever do it though because id like my cars engine to last me through college, well the whole car actually. I do get on the car sometimes and that 2.41 feels best at 85-90 on the interstate going through Atlanta manuvering through traffic.
Old 11-27-2008, 11:58 AM
rtanner's Avatar
rtanner rtanner is offline
it would be better get going about 65mph in 3rd and then snatch it down to 1st while simultaneasly flooring the throttle! then it wont take so long to get 75 mph, once you get use to driving your car like that then you can graduate up, running up it to 50 mph or so in reverse and spinnig it around and going forward with out loosing any speed, and snatch it back to low and run it up to 76mph again, your car will love it you will love it, if you film it we will love it! happy thanksgiving
Old 11-27-2008, 03:29 PM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
Why wouldnt it run 5500rpm? A 350 could turn that no problem provided the valves dont float. The pistons are lighter so the rods are stressed less at higher rpm than a 400 or 455 and they will pull 5500 no problem.
When I was still driving the 10th TA it had 2.73 gears and would shift out of first around 62 mph, the 403 would float the valves over 5200 so it never went over that. That car has a stupid high top end for only a 403. It pulled 5000 in 3rd without any effort, but I wouldnt suggest our friend Jack attempt that because with 2.41 gears that is really moving. Just enjoy the low revs on the highway and better mileage when you are cruising 70mph on I-75. Just drive intelligently, not like you have a Civic with three wings, neon lights, and a fart can under the bumper.
Old 11-27-2008, 08:01 PM
Skip Fix's Avatar
My TA with the stock 180 hp 400 would only pull 4000 in high gear, 130+ though.
Skip Fix
Old 11-27-2008, 11:19 PM
Danimal's Avatar
Danimal Danimal is offline
I had a '79 malibu Landau in high school that had a 2.29:1 gears. That's right. 2.29:1. When I bought it, the 267 v-8 was dying so I dropped the 283 in it from my '64 Impala that was very well built (forged pistons, shotpeened rods w/ARP bolts, balanced, better springs, ect) and with a 3" stroke it would turn 6,500 rpm easy. While it wouldn't drop any jaws when launched, that thing would absolutely fly in first gear--75 MPH easy. :-)
It's a different feeling in my '69 with the 3.23's, as I keep waiting for another upshift to occur. :-)
Happy thanksgiving, guys!
Dan
Austin, Texas
Antique Gold 1969 Pontiac GTO YS400/TH400 3:23 10-bolt
2009 Pontiac G8 GT Maverick silver/Black Interior
1997 Chevrolet S-10
Old 11-28-2008, 10:44 AM
PITTSBURGH 64 PITTSBURGH 64 is offline
I love having a 2.56 with my RA-4 cammed 462. However I have a 4 speed hydro...
http://www.youtube.com/watch?v=jH95PE4P-Ow
http://www.youtube.com/watch?v=H0CCMnOu97U
Old 11-29-2008, 12:45 AM
Overkillphil's Avatar
Originally Posted by rtanner View Post
running up it to 50 mph or so in reverse and spinnig it around and going forward with out loosing any speed...
J-turn. Jim Rockford!
Old 11-29-2008, 11:59 AM
dmac dmac is offline
There's nothing like idling in drive at about 80 mph, cruisin down the freeway, with all that power available just by dropping into 2nd. Exhaust just at that vibration stage, engine running at 180 degrees. That has got to be easy on the engine, and doesn't feel like it burns much gas, even though you can see the needle moving.
Old 11-29-2008, 12:23 PM
Region Warrior's Avatar
Not apples to apples, but my st300 shifted on its own at 70-75 mph with 3.23 gears.
Didnt have a tach, so no idea what the rpm was.
Never did find out how fast it would go cause at 145 mph the car(68 FB) would start to float.
Old 11-29-2008, 04:16 PM
Low gear in the ST300 is pretty close to 2nd in a Th350/400, so you will be able to go a bit faster in low than you can in 2st with the 3 speeds. The 700R4 and 2004R have even lower 1st gear ratios, the 700 has a 3.06 where the 350/400 have 2.52/2.48 first gears respectively.
High gear in the two speeds and 3 speeds is always 1:1, in the 4 speed autos 3rd is 1:1 so mph will be pretty much the same in those gears provided the converter isnt locked or slipping excessively.
Fun with numbers. a 2.41 gear with a .62 OD in the 2004R, a set of 28" tall tires, and 5000 rpm = 278 mph.. Stupid fast huh? At 1500 rpm you are traveling around 83mph with the same setup.
You would need at least 5700 rpm and 28" tires to go 145 mph with 3.23 gears, provided there is no slip.
Old 12-01-2008, 01:54 AM
gunmetalgray67's Avatar
gunmetalgray67 gunmetalgray67 is offline
My 76 TA had 2.41s, TH350, and a very mild 400 (headers, Performer, .450 lift cam) and ran 14.97 @ 100. I did not shift out of 1st until the 1000' mark. It would do over 80 in 1st. I outran several Ducatis on the highway. I outran a 95 Stang on the highway and never took it out of second gear. When I stayed out of the throttle I got 18 mpg.
Old 12-01-2008, 12:21 PM
Pontiacman469 Pontiacman469 is offline
Ditto:I Had a 78 Olds cutlass w/a 260 oldsulled it and put in a 307 w/turbo 350 I think it had 2.14 or 2.41 gears.I could "chirp" the tires when i shifted into second around 70mph..slower than hell out of the hole tho.
