Old 12-09-2008, 03:03 PM
drivergto1 drivergto1 is offline
Default SBC being replaced in our school drag car.
We have been racing a 67 Firebird for about 12 years now as a High School drag car. We have been using a SBC under the hood. We want to go back to a 1971 455 Pontiac and do not know what frame towers or motor mounts to use? Any help where to get these or what to use? Thanks you William & Auto students
Old 12-09-2008, 03:52 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Motor mounts:
http://www.jbp-pontiac.com/products/...otorMounts.htm
they are made by mitymounts:
http://www.mitymounts.com/howtheywork.htm
I have them on my car.
The frame mounts can be used from 67-69 birds or 73-74 venturas which came with pontiac motors.
73-74 venturas and 67-69 birds use the same front subframe.
Beware of some aftermarket frame mounts, some have had problems with the fit. Originals work best.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 12-10-2008, 01:31 AM
Steve Barcak's Avatar
I would just add that many '72 Venturas also came with Real Pontiac engines and they will work too.
Good luck to you and congrats on going back to Real Pontiac power brother!
Hosting 11th annual Pontiac Heaven, show, swap, drags, party and all around good time. Saturday April 4, 2009 at Speedworld near Phoenix, Az
Also hosting- 7th annual Nostalgia drags, show and swap coming Sunday April 5, 2009 to Speedworld. Phoenix, Az
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 12-10-2008, 02:22 AM
BVR421's Avatar
BVR421 BVR421 is offline
Originally Posted by drivergto1 View Post
We have been using a SBC . We want to go back to a 1971 455 Pontiac
At last! A post in this part of the forum that makes sense!
Old 12-24-2008, 03:37 AM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Thank You
