Old 12-12-2008, 12:42 AM
john5670 john5670 is offline
Default Convertible body handle 600 horse?
I am building a 1967 firebird convertible with my dad. We installed weld in frame connectors for added strength. The motor is on the way, its a Butler 461 stroker with race ported E-head, port matched victor intake, 4 bolt mains, forged crank, and 950 holley. It should put out around 600 horse and 600 ft/lbs of torque at the crank. Should I have any concern about twisting the frame?
Old 12-12-2008, 12:59 AM
WARPed's Avatar
WARPed WARPed is offline
You should be looking at adding an 8 point roll bar before you do any permanent damage to the frame.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 12-12-2008, 01:13 AM
440GP69's Avatar
440GP69 440GP69 is offline
If you get traction you will twist it bad!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 12-12-2008, 02:30 AM
BVR421's Avatar
BVR421 BVR421 is offline
Put big slicks on it and watch the left front wheel come up about 24" while the right front stays on the ground. Without a good cage even a sedan or hardtop will do that, Its just more exaggerated with a convert. Especially ones without a full frame.
On the other hand if this car is meant for more street than strip, hammer it and have fun!
Old 12-12-2008, 07:30 AM
steve25 steve25 is online now
If you do not have a interlocking type drivers side motor mount, you better chain down that side of the engine once you start hooking!
Old 12-12-2008, 07:50 AM
i82much's Avatar
i82much i82much is offline
Just don't hook the car and you'll be fine, the tires will spin instead. But if you get traction ...
Old 12-12-2008, 07:39 PM
pops65 pops65 is offline
with that kind of power unless you run an 8 point or street tires no track will let you run. my conv runs 10.98 without problems but i have a cage.you will be way faster than13.50 below which you must have a cage for a conv.with that kind of power and any slicks you will be mid 11s at worst.get the cage and have fun.
Old 12-13-2008, 12:16 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Twisting the frame around is one thing, but the load on the engine and trans is another. Hate to see that new butler engine broken.
Old 12-13-2008, 02:00 AM
Sporter's Avatar
Sporter Sporter is offline
I've run 150 shot on my n/a 435 rwhp 67 convertible at the track for years with no issues to the body. I've broken 2 rear axles, a TKO manual trans and ripped the perches off a Moser 9" but have never hurt the body. Doors still close like a new car. I have welded subframe connectors and CalTracs, but no roll bar or cage. The Pontiac ragtops are much tougher than you would expect. By comparison, my 88 Mustang GT was a flexing POS with just a stock 5.0 and slicks. I'll eventually get a 5 or 6 point bar of some kind.
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials.
