I recently purchased the OEM 8 piece inner and outer window weatherstrip set for my 67 convert. I received the kit which was a PUI kit(I knew then I might have issues). The rear side window weatherstrips did not fit at all and I think they were for a hardtop even though the box says convertible. I had some difficulty getting the door strips to fit also but did get one door to fit ok. My question is, is the fuzzy seal supposed to go on the inside or the outside of the window? I ask this because the only possible way to get it to fit was to put the fuzzy seal on the outside. My seals were missing when I purchased the car so I am not sure. It seems to me the fuzzy seal would go on the inside and the rubber seal on the inside. Thanks
"OEM" is OEM and will fit perfect! A full OEM weatherstrip kit will also cost mega bucks.
Fuzzies go inside.
1967 FIREBIRD Street Car Days: 406 cid = 11:46 ET http://www.spottsperformance.com/ima...lyPowell67.JPG |
Sorry, but fuzzies go on the outside.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
