Old 12-29-2008, 07:19 PM
mash mash is offline
Default Cam choice to go with No. 17 heads
Hi, I have a 350 yn motor with No. 17 heads, only mods are edelbrock performer manifold and remanufactured qjet (number says its from 73 olds 350). I have put a set of new lifters and pushrods and a couple of rockers to get the motor serviceable wasnt oiling through two pushrods. all is ok now but want to do the heads up, need ideas for screw in studs and rocker choice along with cam, will also put on ram air restoration exhaust manifolds. Car is 68 lemans with 2.56 rear, this will be changed to a 3.23 or similar. th400 rebuild is also on the cards with a 2000 stall converter. Car is weekend cruiser but would like to wake it up. comp was good on all cylinders around 165 psi. what sort of power could i expect . changing heads or inlet manifold is not an option at thye moment due to lack of availability and freight costs from the US. Also how to change rear main seal to neopreme seal and where to buy it?
Thanks Mark:
Old 12-30-2008, 02:58 AM
72blackbird 72blackbird is offline
I'm overhauling a 350 right now- running ported no.48's, Holley 750 vac. sec., e-performer, Crane 272H cam, new lifters, pushrods, oil pump, ARP rod bolts. I've used this cam before on 350's with 8.6-10:1 CR- it's a good overall performer (272/272 adv. dur., 216/216 dur @.050, 110LSA). This motor is going into my 'Bird to substitute for the 406 in there now, which is coming out for upgrades.
My 'Bird already has a 3.08 posi, Hooker comps and 2 1/2" duals, and the no.48's came off of my 406. I have a Crane 284H in this motor, compression was 205-210 and the motor still runs on pump gas- ran a 13.04 @104 in street trim. I'm thinking with the same heads and induction the 350 should run mid-high 13's.
You'll need to upgrade to an adjustable valvetrain for any aftermarket cam, since the valve lash will be different with the higher lift. Go with straight 7/16" screw in studs to keep the press-in bottleneck studs from pulling out- if you're lucky your head will be machined for them (high performance heads have screw in studs stock). I'd also go for the full roller rockers, as the comp cams roller tip version doesn't do much for the money. You can get aluminum 1.5 and 1.65 roller rockers from Pacific Performance Racing ($195)- not a bad deal there. I'd also go with the graphite rope seal instead (PPR, $20)- as the neoprenes will leak if the seal channel isn't perfect.
Geno
Old 01-01-2009, 06:34 PM
thanks for the advice, didnt know about the graphite rope seal.
