Old 01-02-2009, 12:47 AM
bmidgley bmidgley is offline
Default need advice on tranny mount LS into 69 FB
I am using the TCI front sub in my 69 FB. Installing an 04 GTO LS motor and 4L60E
tranny. The GTO tranny mount will not work. If you want it..free..also free stock 04 motor mounts..
Anyway, I need advice on which tranny mount to use. The TCI crossmember is adjustable, rearward, so that is not an issue.
If anyone out there has done this, please advice. I called TCI, but did not get an answer.
Thanks..
Mike www.pontiactripower.com
