Old 01-04-2009, 09:58 PM
Don57 Don57 is offline
Default 15 x7 Rallies on the rear
Anybody running 15 x 7 rallies on the rear? What size tires are you using? Got pictures? I have recently completed my car BUT I am wishing I had to go with 245/60/15 instead of 245/60/14.
ID:	153505   Click image for larger version
Old 01-04-2009, 10:50 PM
uforacing's Avatar
uforacing uforacing is offline
I have run 245/60/15 on both 15X7 Rally II and 15X8 snowflakes. First pic is 15X7 crosslace with 235/60/15. second is 245/60/15 on 15X8 snowflakes. second pic also shows 14X7 snowflakes with 215/70/14's.
ID:	153523   Click image for larger version
Name:	oldgroup 818 (Medium).jpg
72 GTO 400-M20 Lucy Blue
86 2+2 Black
09 G8 GT red
08 Torrent GXP (wife's)
09 G8 ST (UTE) black
A pissed off fat house chimp on dope would be a lot more deadly.
Old 01-05-2009, 06:50 AM
ponchbro's Avatar
ponchbro ponchbro is offline
Post
I have 245 60 15's on the rear but have the 15X7 rally's with 4" backspace.The normal 4.5" backspace is VERY!! close to the frame!!!
Old 01-05-2009, 11:08 PM
Thanks for the responses! From what I can determine the 245/60/15 on a 15 x 7 will give me the same sidewall and and same threadwith as I have now with the 245/60/14 on a 14 x 7. The only difference is the 15" tire diameter is 26.6" whereas the 14" is 25.6". Ponchro, when I measure my backspace, I measure from the drop inside the rim, not the outside lip. When I measure from the drop, I get 4 inches on both my 15 x 7 and 14 x 7 rims.
Old 01-06-2009, 06:41 AM
ponchbro's Avatar
Post
You need to measure to the outside of the lip!!
Old 03-10-2009, 12:33 AM
elcaminobill's Avatar
elcaminobill elcaminobill is offline
I have run 15x7 (4.25 BS) on the rear with 205/65r15 tires, no problems but same combo did rub the a-arm in front.
Now run 15x8 with 235/60R15.
Have also run 15x8 vette aluminum rims with 255/60R15
Old 03-10-2009, 11:41 AM
shotgun shotgun is offline
PY Staff -Tech
I have run stock Rallys with 275/60 x15 on the back of my old GP and on my Malibu wagon. I did use the 3/8" (I think) to keep them off the frame.
Up front 235/60x15z fit with a slight rub at lock on the swaybar. I have a huge 36MM Fbody bar so no bar or a smaller bar should be fine.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date [email protected] mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
