Old 01-18-2009, 04:01 PM
garlanka garlanka is offline
Default 67-69 first gen posi
I am looking for the carrier and gears for my first gen bird. I would like to find either 3.23 or 3.36 gears, just need the carrier and gears, not the entire rearend.
Old 01-18-2009, 04:31 PM
foxwolf321's Avatar
foxwolf321 foxwolf321 is offline
same boat i am in. I believe Auburn can help you with it. they have 8.2 bop gears and posi unit for around 800 bucks give or take
Just wait till you drive it!
Old 01-18-2009, 04:39 PM
74 SD455 Formula 74 SD455 Formula is offline
Chris,
I have the original 336 geared rear end that you bought the traction bars from.It is still available.It is a Nodular rear and very hard to find.This was Pontiac's Heavy Duty Rera end. Let me know.
Old 01-18-2009, 06:39 PM
D. Rustin D. Rustin is offline
you 'll have to decide either 3:23 or 3:36 because thats the cut off for 2 or 4 series carrier.
Old 02-12-2009, 09:11 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I'd recommend thenew Eaton unit as it's fully rebuildable (the Auburn isn't) and has available upgrades like carbon fiber friction material and 800# preload springs.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 02-23-2009, 10:04 AM
Cammer-6 Cammer-6 is offline
I have an NOS 4 pinion unit
not cheap but its the real deal GM one.
Old 02-23-2009, 02:42 PM
wbob69's Avatar
wbob69 wbob69 is offline
Default 3:23
Same boat here also. I am thinking of going with an auburn 3:23 complete set up. Keep us posted on what you do...would like to know which route you take and how it goes.
Old 02-23-2009, 10:31 PM
limejudge69's Avatar
I was in the same boat as you guys. I have a 67 Firebird with a 2.56 non posi rear. I found a rear from a 72 Nova. Monoleaf springs. 8.5 10 bolt. I have less than $700 in the whole thing and that includes a new set of gears, bearings, shims, and a fresh posi unit. Any 68-76 Nova, Ventura, Apollo, and Omega rear will work. Plus the 8.5 is stronger than the 8.2 Just something to consider.
Old 05-27-2009, 05:28 PM
Bump - still looking for a posi for my 67 bird. At this point I am more interested in a 3:55, but would still be interested in a 3:36.
Old 05-27-2009, 06:14 PM
Default 336 Posi for sale
I still have the 1967 " N " nodular Posi rear end for sale with the 336 gears.I am still asking $900.00 for it plus shipping.This was removed from a 1967 326HO 4spd. car.Let me know if you are interested.
Old 06-02-2009, 12:15 PM
GreenBird GreenBird is offline
I have a rear from a 68 firebird with a 4 series carrier and 3.90 gears. $375 There is nothing wrong with , I just replaced it with a 9 inch to back up the 462 motor. The 3.90 was the perfect gear for waking up the original 350 HO motor on the street. I am located in Maryland.
Rick
Old 06-03-2009, 11:19 PM
I am interested, but a bit worried the 3:90 gears may be a bit much for my 326 block / M20 4-speed.
Old 06-04-2009, 03:48 PM
I was running the rear with a 350 and a muncie 4 speed. If you put a 28 inch tire on the rear it will make the gear seem a little smaller. I run 3.90's on the street with a 28 inch tire and the rpms are around 3K at 60 mph.
Old 06-04-2009, 06:55 PM
I am looking to use this car for shows, stock tires and rims, etc., not so much of a performance machine.
Old 06-06-2009, 08:18 AM
GonicGM's Avatar
GonicGM GonicGM is offline
I have new in box 3.36 8.2 BOP gears for $275 shipped in lower 48 US states. I believe they are US Gear. Have a 4 pinion posi also that I have yet to rebuild that will be available.
Gregg V.
Old 06-06-2009, 08:24 AM
I still hve the Nodular 336 posi rear end from a 67 Firebird for sale.If you are not interested you will be able to see it at the Co-Convention as I will be bringing it there for sale.If you want it and can wait until than it will be delivered for free if i recieve a deposit.Let me know...
Old 06-06-2009, 12:50 PM
What are the letters on the axle?
Old 06-06-2009, 12:51 PM
Default Posi and gears
How much for the complete posi and gears?
Old 06-07-2009, 09:18 AM
It is a correct UV coded rear end. Thanks
Old 06-07-2009, 10:53 AM
Default Rear
What is the Co-Convention?
