Old 01-25-2009, 06:48 PM
bmidgley bmidgley is offline
Default TCI subframe in first gen F body
I need some help here. I have installed a TCI front subframe assembly into a 69 Firebird. I have the 04 GTO motor and L460e tranny in the car. Either the transmission is hitting the floor, or the rear mount on this TCi kit is too high. If I lower the tailshaft about 3/4" everything looks OK. I am having difficulty determining what is the problem. I could mod the tranny mount pretty easily, but then I am not sure if the orientation of tailshaft to the pinion would be correct....
Any help would be appreciated....
I called TCI and did not get much help, although they did try. I can't be the only one dealing with this...
Thanks.
Mike Wasson
(309) 360-6385
Old 01-27-2009, 08:12 PM
amcmike's Avatar
amcmike amcmike is offline
Can't answer your question, but is this a 17,000 mile original 400/TH400 A/C car from Southern California by chance?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 01-29-2009, 02:22 AM
Default what car?
No, this is not a 17,000 mile car from southern CA.
Thanks for your help.
Mike
Old 01-29-2009, 06:32 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
are the frame bushings the same thickness as the old ones? check frame mount heights?
