Old 01-28-2009, 04:24 PM
rad400 rad400 is offline
Default rear sway bar
Will a factory rear sway bar fit with an aftermarket aluminum deep rear pan cover?
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 01-28-2009, 07:30 PM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
Don't know the answer for sure, but my gut tells me yes. I can't imagine that they would make a part like that and not fit with a standard piece of equipment.
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 01-28-2009, 08:32 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
A factory sway bar fit to a 64-72 a body is routed UNDER the housing ....a little forward of where the cover bolts up.....
Old 01-28-2009, 10:23 PM
GT182's Avatar
GT182 GT182 is offline
Conrad, doesn't your swaybar sit under the housing on your Firebird? I'm trying to remember how mine was. Shouldn't matter what type of cover is on the housing if it does.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 01-28-2009, 11:05 PM
the sway bar was missing . A friend of mine gace me one and I am getting the drop links for it
Conrad
Old 01-28-2009, 11:11 PM
67 Lamnas's Avatar
Sorry.....didn't realize you had a bird....
