Old 02-02-2009, 08:43 PM
Greg 66 Greg 66 is offline
Default 744 cam spring recommendation
I was looking at the 68404-16 - Crower Valve Springs. Is the seat pressure of 113lbs going to be sufficient or is there a better choice.
Old 02-03-2009, 04:21 AM
ta man ta man is offline
Good choice.
Old 02-03-2009, 07:10 AM
steve25 steve25 is offline
thats fine for break in, but after 1000 to 1500 miles I would add atleast a .030" shim as that 113 lbs will drop off to around 106 and you really want to see 120 to 125, so at that point a .060" shim would do the trick.
I would try both size shims now and note how much pressure they add so 1000 miles from now you know what shim to stick in.
Old 02-03-2009, 12:58 PM
track73 track73 is offline
Why would you need that much spring pressure for a hydraulic cam that won't see 6000 RPM? I'm just curious.
Old 02-03-2009, 01:06 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Seems like 110# @ 1.59" would be plenty...after break-in
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a
66 Star Chief Executive 57k mile
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
Old 02-03-2009, 03:32 PM
Kenth's Avatar
Kenth Kenth is offline
steve25 is on the money.
Pontiac used 125lb@1.586" installed height on the #744 for a reason, valvefloat.
I tried the "std" valvesprings of my lowmiles 1971 #96 heads with the #744 and the engine refused to rev above 4500rpmīs, i switched over to the valvesprings (used) from a set of #48 heads with the correct strength and the engine now revīs until the TH400 shifts at 5400rpmīs.
Also, a quick look at the lobes of a #744 will give you an idea why the somewhat high valvespring pressure is required?
I think most people trying the #744 and dislikes it used too weak valvesprings for it.
1973-74 455SD uses the same grind as the #744 with 110lb@1.800" installed height springs.
Old 02-04-2009, 01:34 PM
bobzdar bobzdar is online now
I used stock springs and did not have an issue with this cam. I missed a shift and the engine saw somewhere around 7000rpm and did not float the valves. I probably was lucky (well, maybe not, it would have been nice if the valves had floated at 6200rpm and the springs weren't worn out or had been replaced at some point. I'm now running crower springs, not sure on the pn. This is a good cam in a manual trans car, lots of fun with good top end and still pulls 12-14" vacuum at idle.
Track73, In a 400 it will pull to 6000rpm easily. I ran it with a T1 and it felt like there was more left after 6000rpm but I didn't dare go higher with stock rods/bolts. I think an unmodified stock intake will have best shift point at 5700rpm or so.
Old 02-04-2009, 02:12 PM
[QUOTE=Kenth;3556477]steve25 is on the money.
QUOTE]
Kenth,
Using 35+ year old stock springs on a build is never a good idea.. I doubt they had over 75# on the seat. I used to use the Erson springs all the time and also had good results, I have swapped aftermarket used springs from one set of heads to another but only if I new the history/age of it.. worked good.. 125# on the seat is on the high end most hi-perf cams and with a low-lift cam with gentle ramping I don't see the need. I have yet to try a 744 would like too..
Old 02-04-2009, 02:40 PM
68bird400HO's Avatar
I am using the HO VS-11 springs. They are stock dimensions and give around 120# seat pressure @ 1.59. They list that they are good up to 0.517 lift but Ken at HO says they will handle much more than that without a problems. Great spring and they are very reasonable pricewise.
http://www.hoenterprises.com/WSFF/ho...?vCompID=27383
Old 02-04-2009, 04:18 PM
Springs I have tested usually loose about 10% after run a while.
