I was wondering if any of y'all with '69 built Baltimore a-bodies would mind contributing a bit of information? I'm trying to determine the extra codes on the trim tag [data plate] of the '69 model Baltimore built Chevelles, but I noticed that the Pontiacs share this 6-digit code in the lower-right quadrant of the tags as well.
What I'd ultimately like to see are some build dates followed by their corresponding 6 digit code...also, does the PHS info show an actual *production* date, or just a ship date? Anyway, I have a rough *theory* on this 6 digit code [you folks may already have figured it out] but I need just a larger sample of cars to see if it works out... Thanks in advance, and take care...
Rob Clary '69 Yenko Camaro - high 11s @ 118, Pure Stock! |
No production date--does have the ship. But the ship date is from the factory if bound for a dealership at that time. If a zone ordered car, the ship date is from the zone lot to the dealership.
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars." Some people know all of their rights, but none of their obligations. |
I'm trying to look for any commonalities of the Baltimore A-bodies to help narrow down some information...Thanks!
Rob Clary '69 Yenko Camaro - high 11s @ 118, Pure Stock! Last edited by Chevy454; 02-06-2009 at 03:37 PM. |
What is your theory--a Baltimore A-body vehicle numbering? (Also, I have not found a build sheet.)
I don't know what the numbers mean but there is definetly a pattern. The Body numbers are all over the place but the 6 digit numbers always stay in order.
I have the following info: VIN build date Body # 6 digit # B107678 09C 503204 016031 B110236 09C 516654 021668 B122223 10D 527185 044554 B125043 10E 530927 050164 B126014 10E 533488 052040 B127747 10E 527794 055508 B137436 11D 544610 073643 B150249 01B 558552 089157 B151222 01B 548953 101016 B151829 01B 557813 102579 B156002 01D 558063 116620 B156677 02A 566342 118620 B163075 03A 566274 138132 B164889 03B 573646 144717 B166394 03C 574614 149430 |
I'm thinking the first 3 digits are a Julian date and the last 3 digits we know are a daily sequence number. So, in that 6 digit number you'd have which car off the line on which day...
It may tell us in what order cars were built--maybe not. John, thanks for running down all that info!
I think he is saying the first 3 digits would be the Julian dates of that model year (which would be Sept.-Aug. approx), so John's first example 016031 would be the 16th day of the model year, and the 31st car off the line that day. Correct me if I am wrong on that...
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
Don't have trim tag at the moment
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
That may not be correct, but if it is, then my Judge's 112879 is December 21, 1968. Maybe I am not looking at this correctly. Interesting though. John, do one of your 01B's represent a Judge?
Maybe just a shot in the dark, but it explains why the numbers are sequential in regards to build date...
Rob, thanks for bringing this up.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
Basically, the flow of information goes like this: The dealer initiates the order which is tracked by the Dealer Order Number. This is an alpha numeric code (there doesn't seem to be any pattern in terms of sequence or alpha characters, like "PAE175", or "JDCXZB" or "JDCW65"). This number is used to track the vehicle/order until it reaches the vehicle assembly plant. Once the order is screened for correctness and material availability and passes this check it is "committed" to the assembly plant. At this point the CSN is established. Vehicles are built in CSN order and are tracked through the body shop and paint shop until the VIN is established and affixed to the body. Once the VIN is established it takes precedence over the CSN. (Incidently, in my most recent assembly plant - the Mishawaka H2 plant, to be specific - the vehicles pop off the end of the line in CSN order, not VIN order). Here are some carriers in an assembly plant, to give you a flavor of what I am talking about: ![]() I tried to find in my files some matrices that showed actual vehicles being tracked by the Order Number, CSN, VIN and GM Company Owned Vehicle Number (for GM pre-production vehicles) but I didn't have any; the reason being is once I had the VIN I deleted the CSN because I no longer cared. I had the VIN and the GM vehicle number and with those two numbers I could track any vehicle through any durability testing/validation testing, Captured Test Fleet usage or retrofit activities and subsequent sale or auction. I mention all this because I wonder if the six digit codes you are seeing are the equivalent of what I am calling the CSN. Disclaimer: I base this on my experience in GM assembly plants, which started in 1979. I have built preproduction properties in every GM Full Size Truck assembly plant in North America over the last 30 years, so while I have lots of truck experience I have zero experience building Pontiacs or Chevys in Baltimore. I share these thoughts, which may or may not apply here, in the hopes that this may further stimulate your own thoughts/theories. FWIW - K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 02-09-2009 at 12:14 PM. |
Keith, how was the 6 digit CSN derived?
Was it based on Julian date and order on the line? Just picked out of the air? Starts at 1 and increments with each vehicle coming out of the body plant?
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
I should add it starts at 0001 with the very first pre-production units in the plant (what we would now call Manufacturing Validation Build - NonSaleable) and increments up through the whole model year. It would then reset at 0001 for the next model year. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
68gtoMN, your Judge turns 40 this week.
Keith: what info does a Baltimore-Pontiac "Body Broadcast Copy" show? For the Chevelles, it lists a "sequence" number, "serial no." [vin#], "ident number" [body number], "order no." [I believe this to be your CSN number, as it's 2 letters followed by 4 digits], and "F&SO or COPO no."...often times, a "job number" is on Chevelle paperwork as well...the rest of the broadcast copy shows a crap load of options & such, naturally.
Anyway, from the 6 digit number on the trim tag, the last 3 digits are always listed on the buildsheet box 24 as "DP sequence #", which leads me to ask "sequence # from which specific day?", which is where my Julian date theory came from.
Sorry Rob - didn't see this til just now.
I'll see if I can find a '69 Baltimore build sheet (Pontiac branded) and post it here. I don't think the Order number you mentioned is the CSN; the format doesn't sound right (plus - the "Order number" might be the actual Dealer Order number). I stole this from a post I made over at V8Buick. This comment was made in the context of Chevrolet, Buick and Oldsmobile brands going down the same line. Perhaps it will be helpful here: Quote:
Bump. Good info here for another thread.
