Old 02-18-2009, 02:40 PM
dgas's Avatar
dgas dgas is offline
Default Sprint 6 engine ???
I have a Sprint 6 4bbl intake, split exaust w matchinhg head. the block is long gone + I am curious if it will fit a 292 Chevy block or if just the intake /exaust manifold will ? ?
Old 02-18-2009, 05:10 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Can't answer that but I might have some options.
I have a block, crank and rods from 69 FIrebird, no other parts except bare block. Also have a complete 69 1 bbl engine. Might be interesteed in buying your stuff too.
Old 03-10-2009, 11:09 AM
dgas's Avatar
I am sorry, but the intake /exaust is not for sale and I can get a Sprint sixs locally, not rare at all around here. I just want more cubes w/o doing the big bore/stroker thing.
Old 03-10-2009, 05:49 PM
Jeff Hamlin's Avatar
NO & NO.
However your chebby engine guts can be cut and used in our OHCs
Old 03-10-2009, 06:24 PM
dgas's Avatar
Got instructions on how to install the 4bbl intake on another site, But I have to split the stock 292 exaust manifold. The Sprint Dual Exaust will not fit.
Old 06-09-2009, 08:23 PM
Overkillphil's Avatar
There is a guy further up in this section looking to pull his OHC 6 in favor of a SBC. FYI.
http://forums.maxperformanceinc.com/...d.php?t=599259
Old 06-09-2009, 10:27 PM
Transam Stripper's Avatar
Transam Stripper Transam Stripper is offline
I have a OHC 6 (not a Sprint) with 88k on you can have if you come get it out of my garage. You gotta take the whole thing though.
I'm older now but still runnin, against the wind. Bob Segar.
Old 06-10-2009, 11:59 AM
Cammer-6 Cammer-6 is offline
details please
PM me if you want
Old 06-10-2009, 05:32 PM
I pulled it out of a '69 Bird seven years ago to put a 400 in it. The guy said he wanted it back but that was 7 years ago. I live North Of Atlanta. I aint shipping it. 678-278-5116 Bill
Old 12-11-2010, 10:03 PM
marxjunk marxjunk is offline
20 years ago my uncle put a sprint 6 intake and exh mans on a 230 chevy.
heres what i remeber...he had to grind one or two push rod tubes out and used small brass tubes.
he made an adapter plate out of 1/2 inch plate and it was a bolt on...the ports all line up just some bumps and stuff in the way...it all worked, and i got to ride in the car...
he took a 230 intake and man gaslets and the sprint gaskets and figured out it would work, he was good at adapting etc..
he took a 230..they have steel cranks...and put a 194 head...bumped the comp up like over 10 to 1 ..and used a factory 3 speed overdrive and shoved it all in a 67 elcamino...cant remeber much else, but it was way more efficient and got some ungodly amount of mpg...
i dont know what happened to the car, he passed and we where estranged for years..he got weird i got busy with life...
