Old 03-15-2009, 05:14 PM
voyager77 voyager77 is offline
Default 79 T/A gas pedal replacement
I want to replace the gas pedal on mine as it looks pretty crummy. Feels like there is a pin/spring on the back side but its tough to get to. Do you have to unbolt the 3 bolts the hold the arm to the firewall to get to it? Any tips? Thanks All.
Old 03-15-2009, 08:24 PM
Ollie's Avatar
Ollie Ollie is offline
Yes first disconnect the throttle cable then unbolt the three bolts. The throttle cable is sweaged on the end pull it back a little bit there is a slot in the end of the rod that the cable slips out of the rod end.
Its ok to giggle and snicker, Dont laugh and point
