Old 03-19-2009, 02:59 PM
SD73's Avatar
SD73 SD73 is offline
Default 1993 Bonny Keyless Entry
Hello All, got hopefully a quick one for you. I wrecked my Bonny and I want to pull the module for my keyless entry and move it to my Olds of about the same year. Does anyone know where the module is located and if it will work in other models that weren't originally equipped?
Thanks!
Old 03-22-2009, 01:25 PM
The module should be behind the glovebox. I doubt the olds is wired for the system if it doesn't have it already.
Mike
former." --Albert Einstein
- Winston Churchill
Old 03-23-2009, 11:39 AM
SD73's Avatar
Thanks Mike. I had a look underneath the glove box while trying to check for it and using my existing clicker to see where the noise was coming from but I couldn't pin point it. Do you have a description or a part number? I'm pretty sure you are right though. I had a look at the Olds and did not see any extra harness in that area.
