Old 03-24-2009, 08:59 PM
oldman oldman is offline
Default Bracket
I need a throttle cable bracket that fits on a 1969 intake manifold.
I have one part #9792068 but it does not align with the last intake
bolt and the boss on top of the manifold.
Does anyone have one?
Keith
Old 03-25-2009, 08:49 AM
REBOLD REBOLD is offline
Default throttle bracket
You have a bracket for a 1968-69 2bar.Bracket listed for a 4bar is 9792069.Unfortunately I do not have what you need.
Old 03-25-2009, 09:18 AM
428PHIL's Avatar
428PHIL 428PHIL is offline
Don't know if this will work, but I have the bracket (9787161) that I took off my 66 LeMans. Cable came through the firewall and mounts to bracket.
Old 04-09-2009, 01:35 PM
wrea3_98 wrea3_98 is offline
Default RE bracket
I have a very nice throttle cable braket from my '69 Judge 4234 intake. There is no part# stamped on it but it fits perfectly. May be aftermarket. I found a numbered one for my restoration so this one is good to go.
Old 04-09-2009, 03:46 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
The correct bracket for '69 should be stamped T-4 same as the one below.
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 04-09-2009, 04:20 PM
Default RE bracket
The one I have has T4 stamped on it like this one. My original has the GM part number 9792069 stamped on it. Both will work. Most of the aftermarket ones now have the GM
number stamped on them.
