wassap poncho freaks!
i was wondering what engine mounts are used to install a 1969 354 into a 78 t/a. as of now, i have a set of 68-72 GTO, Tempest,Lemans rubber mounts bolted on the engine. the engine is sitting in the engine compartment, but the lower mount hangs half way off the crossmember. is there a bolt on solid mount i can use? thanks for your help!
i had a chevy engine once, then i got a pontiac
You need the motor mounts from a 1970-1979 Pontiac v8. But those are 3-bolt mounts and 1969 blocks aren't drilled and tapped for those extra 3 bolts, so you need adapters. Most of the local parts vendors (PY, Ames, etc) sell them. The fit isn't stellar and perfect, but it works.
excellent!
105 a pair??!!!!?? jesus! there chargin alot now a days to drill 4 holes and tap 2! off to the garage!
