Hi everyone, Ive got a 79 TA that has the factory rear disc package. Ive developed a rattle, or clicking sound in the passenger side rear caliper. It goes away as soon as I touch the brake pedal, then starts back up again soon as I step off the brake. Question is: do the rear disc brake pads have the same kinda retaining clip that holds them inplace against the calipers piston like the fronts have? Thanks.
There is a cheesy thin wire clip that fits in a groove around the piston and grabs the bottom of the pads. Easy to pop it off. Teh pads may be too far off the disc also if you haven't been setting the E brake enough or the ratchet has frozen causing some chatter.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
If the clips are the same as the 79-85 Eldorado/Seville/Toronado rear disc brakes cars, I have the clips.
shouldn't be - Eldo's are 2-1/8" diameter, T/A's are 2-1/2"
Thanks for the info guys. I had totally forgotten about that little bugger being there. Been 6 yrs since I installed the new calipers on it. Skip i think you hit the nail on the head about the clatter. I installed theses calipers new and never hooked up the E brake,
my bad as my kids say.lol. I bet they are frozen up from not being used. Makes sense. Now where did those rear caliper E-brake cables I bought go?? Thanks again
Reviving this old thread.
Anyone have any of Trans Am 2.5 inch rear anti rattle clips. Even used ones? I think I looked everywhere and cant find any. Part number 179-841 or 18004026. THX |
I have a set of them if you still need, PM me for info. I also have the repro E-brake cables just pulled from a 1980 TA for cheap price if you or anyone seeing this needs them. Will be listing for sale on here soon.
PM sent
