Old 05-03-2009, 08:00 PM
The Bird The Bird is offline
Default What trans comes stock in..?
What trans came stock with a 1977 Formula 400?
Old 05-03-2009, 10:17 PM
2manyT/A'S's Avatar
It would likely depend on the engine/trans package spec'd,but could have been TH350,BW ST-10 or possibly Saginaw?
Does it have a clutch pedal? W72 option?
Old 05-04-2009, 11:21 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Stock automatic was a TH350 in that year. On a manual it would be the BW ST-10 as I am not sure the Saginaw was used behind the 400, but it very well could have been (not really sure there).
Old 05-04-2009, 05:53 PM
77 TRASHCAN's Avatar
If it is an automatic, it supposedly can only be a th350, has to do w/ the cat. converter.
Hot Rod magazine had an article w/ a prototype 1977 T/A, it had a TH 400, but none came in production models......if my memory is correct... I still have that magazine somewhere...
Shut it off
Shut it off
Old 05-04-2009, 10:21 PM
se428bandit's Avatar
se428bandit se428bandit is offline
I remember a yellow 77 Formula used back then but it was 4 speed non air car.They also pulled the belts and drop the exhaust at the convertor and it ran 14:20's.
Old 05-05-2009, 10:07 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
I have a magazine with that roadtest, I swear it was an automatic TA 6.6 Formula with 3.23's... 14.2 @98 with open exhaust and air cleaner removed..
[/I]
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
