Missing Pontiacs, Parts or Trailers Include lost or stolen items here
Old 05-12-2009, 09:36 PM
lazlo's Avatar
lazlo lazlo is offline
Default Hitch broke
So I hear this hellasious noise this morning. I look out my front window to see a telephone pole down , tangled up in a trailer with a crawler on it... It's obvious by the photos that the crawler was loaded way to close to the front of the trailer.. to much tounge weight, But it brings up a good point!
WHEN WAS THE LAST TIME YOU CRAWLED UNDER YOUR TRUCK AND TOOK A SERIOUS LOOK AT YOU HITCH ASSEMBLY...
This was an aftermarket hitch on a Dodge Duelley. Try to imagine your prized posession on the trailer, and watching it pass you dragging your hitch... Or worse yet having this rig go left of center at 40 mph & hitting a car doing 60 mph hitting it head on..
ID:	168406   Click image for larger version
ID:	168407   Click image for larger version
ID:	168408   Click image for larger version
ID:	168409   Click image for larger version
[SIGPIC][/SIGPIC]
http://www.gogtoaa.com/leibys%20rides.html
Old 05-13-2009, 12:47 PM
60man's Avatar
60man 60man is offline
Yep....do do will happen !!
I check my equiptment prior to every tow. Check,hitch,air pressures,lights,tires,and retorque lug nuts often...Never take it "things are fine".....
ECM member.
MANDRA
Old 05-14-2009, 05:14 PM
62Lemans
Guest
Posts: n/a
Couple of people killed on the Bay Bridge (MD) coupla years ago because a guys hitch broke and the trailer ran into the oncoming lanes (plural) and hit several cars. They couldnt even dodge it. No where to go.
Old 06-01-2009, 07:39 PM
gtokid68's Avatar
gtokid68 gtokid68 is offline
Cool dodge thing
the same problem happened on the 01 Dodge were I used to work at about 250000 miles didnt break all the off way of though. They got lucky. Its amazing how many people just check lights and go. This is why the DOT is so hot and heavy on these trucks!!!
Old 06-01-2009, 07:56 PM
rockertype's Avatar
rockertype rockertype is offline
WOW! A little more speed and you might have had that thing in your living room!
1967 FIREBIRD Street Car Days: 406 cid = 11:46 ET
http://www.spottsperformance.com/ima...lyPowell67.JPG
Old 07-16-2009, 10:11 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Ouch! Doesn't look like safety chains would've helped as the hitch failed.
Around here you're required to have a trailer brake battery backup with a lanyard attached to the tow vehicule. If the hitch separates the landyard activates the brakes.
Uhh.. Why would a guy stand on a metal trailer with a downed power line sitting on it??
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 07-18-2009, 01:09 PM
SRR's Avatar
SRR SRR is offline
Break away brakes are required in all 50 states.
― Calvin Coolidge
Old 07-18-2009, 01:54 PM
lazlo's Avatar
I made the same point.. It didn't seem to bother him anywhere near as much as it did me...
They don't do you much good, in this situation, if you have them attached to the hitch, as most folks do..
[SIGPIC][/SIGPIC]
