Old 05-17-2009, 12:19 PM
john5670 john5670 is offline
Default Where to buy custom drive shafts?
I am looking for a high quality drive shaft for a 600 hp/ 600 ft trq. motor. Its a 1967 firebird with a TKO 5 speed and GM 12 bolt. Anyone have a suggestion where to buy one and if I should buy aluminum or steel?
Old 05-17-2009, 12:22 PM
Ron H's Avatar
Ron H Ron H is offline
Where are you located?
Inland Empire in CA makes good ones. I am running a 3.5" aluminum 1350 yokes. Supposed to handle over 1000 ft lbs and HP.
http://www.iedls.com/
68 Firebird
Are you running with the wind or breaking it?
Old 05-17-2009, 12:24 PM
I am located in Minnesota.
Old 05-17-2009, 12:25 PM
Walter Lansing's Avatar
Walter Lansing Walter Lansing is offline
I have heard alot of good things about Denny's. As far as aluminum or steel what will your budget allow and what are you doing with the car. Denny's usally has a 4-6 week wait. You may also contact some local chassis builders and see if there is a local driveshaft shop thay have good things to say about.
Walter
1964 Tempest 9.73 @ 136.9, 525, Kaufman D-Ports, Pump Gas 3670 W/Driver.
In the 9's on pump gas!
Old 05-17-2009, 12:33 PM
Ron H's Avatar
http://www.pstds.com/custom_driveshafts.htm
These guys are in Florida.
http://www.dennysdriveshaft.com/
Dennys are located in NY.
Inland Empire will have you a driveshaft in a week.
68 Firebird
Old 05-17-2009, 02:01 PM
ponjohn's Avatar
ponjohn ponjohn is offline
fleetpride
Old 05-17-2009, 02:21 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
I've used Strange for a few chromolly shafts. They are reasonably priced and quick turnaround. About a week if I remember right.
66 GTO
Old 05-17-2009, 02:49 PM
Sporter's Avatar
Sporter Sporter is offline
I've used Denny's and PST. Both worked well. Denny's has the better customer service but PST is quicker. If you can find the right size, the used 4" steel NASCAR driveshafts are pretty affordable at $75.
http://www.musclemotorsports.com/dri...eel--used.html
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials.
Old 05-17-2009, 02:52 PM
bad69bird's Avatar
bad69bird bad69bird is offline
I use Inland Empire...no complaints here.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 05-17-2009, 03:12 PM
theYman's Avatar
theYman theYman is offline
I wouldtry these guys.... I bought a used NASCAR shaft from them for $75!
http://musclemotorsports.com/drivetr...eel--used.html
The shaft I bought was very nice with 1350 ends.
Trent
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
Old 05-17-2009, 03:53 PM
roadrage david roadrage david is offline
Dannys in my book (and car)
Old 05-17-2009, 04:56 PM
GTOLou GTOLou is offline
I called Denny's and they had like a 6-8 week backlog (now, they are probably the greatest guys in the world, but the impression I got was "we're the best and are in demand and you'll have to wait some....).
Anyway, Driveshaft specialists had one to me in like 2 weeks.
http://www.thrashdriveshaft.com/
Very thorough and a little cheaper than Denny's. Yeah, you've got to be good with the measurements....
They'll always get my business..
Old 05-17-2009, 05:11 PM
Money Pit's Avatar
Money Pit Money Pit is offline
Denny's is the place. I live just 15 miles away from them, they are great people. They treat you right, yes they have a backlog, but that tells ya something! They're the best and treat ya right! They stand behind there driveshafts quality, no questions asked!
Jeff
Old 05-17-2009, 06:17 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Money no object,I'd get mine from Mark Williams Ent.
This space for rent...
In the meantime,check out the cars HERE.
Old 05-17-2009, 06:28 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Find a good truck driveshaft place (one that can build what YOU want). I got mine for $250 out the door with HD U-joints, and balanced a few years ago from a local place. They told me if I break it to bring it back, and they will make another. No problems yet, and they told me it should be good to around 900 HP.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 05-17-2009, 06:45 PM
Denny's told me 6-8 weeks when I called them 2 years ago. Guys, Were talking about driveshafts here! My opinion for what it's worth, is that they are grossly understaffed to consistently be that far out. As far as them being the best, that seems to be self proclaimed. I don't know about any failures with application specific driveshafts from any of the other well known driveshaft suppliers, again we are talking about driveshafts here, not rocket science. JMO
66 GTO
Old 05-17-2009, 07:18 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Call Vince at VRN in Lake Bluff IL (847) 735-7270, they actualy make shafts for Strange
www.pro-touringf-body.com
Old 05-17-2009, 08:00 PM
Money Pit's Avatar
I guess I'm just a little bias to the hometown people. But Denny's are good people and make a great shaft. All said a well built driveshaft that is properly spec'd is all you will need.
Old 05-17-2009, 08:44 PM
Tom McQueen Tom McQueen is offline
M/W are the only driveshafts I use.
Old 05-17-2009, 09:48 PM
SLICK1 SLICK1 is offline
Thumbs up
I have a Dynatech unit made in aluminum for just under $400.00 and shipped to my door with a one week turnaround!
http://www.dynotechengineering.com/
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
