On an 81 GP the drivers door wont open
its unlocked and I took off the intior top panel the rods are attached and moving but is there someway to get the latch to release? |
Sounds like one of those deals where the lock isn't really unlocked even though the lever and key cylinder feel like they are working. They get gummed up with old grease and years of dust, and one day just stop working. Unfortunately, it's always in the lock mode when it happens.
Murphy's law.Try to get a long narrow screwdriver or prybar down in there from whatever you can access, and force the lock open at the source. Youwill have to determine which way the lever moves on the lock itself, by pulling on the lock plunger.
Seeking recovery of my stolen 1988 Buick LeSabre T-type. Primary summer driver & Road Trip car. Garnet Red with 2007 PENDOT inspection stickers on windshield. Had minor damage to left rear quarter & bumper. Last three of VIN: 301 Could be being driven with altered VIN. Bodywork on left rear quarter (near the tail light) would be a tip-off. Last seen by a patrol officer doing a routine plate check in Gary, Indiana, August 31, 2009 (The thieves were driving, but my plate was clean.) |
You'll might have to get the bottem panel off as well. I had to use a screwdriver and push down on the lock part that is on the latch mechanisim....where it hits the strick bolt on the door jamb...
I was inside the car and the other door had a broken handle. I got out pretty quick! |
I did this 3 weeks ago on my Wagon. Geeting the panels off were a real treat with the door closed and locked!!!!
Anyway, I used a mirror to see what I was doing and it took a few tries, but did get it to unlock. One of the little clips had broken.
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date [email protected] mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) |
Sprayed wd40, jiggled rods then used a mirror and light and
discovered that the rod for the interior latch was loose and jamming the lock rod so that it wouldn't unlock Thanks for the tips Brad |
