Old 06-04-2009, 02:26 PM
65gto69's Avatar
65gto69 65gto69 is offline
Default Cleaning out garage
Hi Guys,
Being laid off and unemployed for well over a year, I need to start selling some of my Pontiac stuff that I had for future projects but will not get to before I run out of money.
1) A set of 4 1966 Pontiac rally 1 wheels with centers and after market original rings. This is an original set had them for over 20 years, mounted on tires. Great condition but do not know the code because of having tires mounted. $1000.00 pick up only.
2) 1965 tri-power intake in great shape except when I purchased it someone welded the heat tube areas shut, other than that in really great shape and have used it about 20 years ago. I am missing the front carb due to a fire, but have the center and the rear., and 3 repo chrome air cleaners with paper elements. I am sure the welded tubed can be opened and put back to stock, I never worried about it never used the choke. $900.00 pick up only.
3) 1966 tri-power intake, needs to be tanked or blasted, a couple broken studs need to extracted, no carbs, linkage or waterneck, just the intake. $250.00 plus shipping or can pick up.
4) 1965 421 WG block with #157 at back of motor with matching arma steel crank. Missing the 4 bolt caps but comes with 2 bolt caps. Bores measure 4.09, crank measure 3.25. Block should be tanked and bored to desired size, crank should be turned has surface rust on the journals. $1200.00 pick up only.
5) 1968 Pontiac 400 YC motor. This was pulled about 3 years ago and was running when pulled, I replaced with the motor in my signature. This motor was my pride and joy and has great power. Motor has 3.75 stroke arma steel crank, polished 58-62 forged rods, trw 30 over pistons, total seal gapless rings, clevite bearings, crane cam flat hydraulic 495/510 lift, 1968 #16 heads, have been ported and bowled flowed 250 at 600 lift, misplaced sheet, crane springs to match cam, stamp steel 1.65 rockers, polished torker 1 intake, R.A.R.E. 1967 Pontiac HO cast iron headers, chrome tall baffled valve covers, timing cover, water pump, pulleys, dist w/ accel hi-po points, condensor, cap & rotor and accel yellow superstock wires. Motor should be gone over because of sitting, stored in climate controlled garage since pulled. $2500.00 pick up only.
6) 1965 power brake booster and master cylinder, removed from car due to new motor, no room between valve covers and booster and not enough vacuum, worked great when pulled 1 year ago. $200.00 plus shipping or can pickup.
7) A set of 1974 4X-1H heads, screw in studs, big chamber 455 heads, these need to be redone, was going to use these to build a blower motor with the 421 block, but obviously that is no longer going to happen. $150.00 pickup only.
8) A pair of Cragar SS wheels mounted on tires, great shape, stored in garage for over 20 years. Wheels are 14x8 with dish in front, tires are super sport zebra stripe 245/60/14. Wheels have original Cragar center caps. $250.00 pick up only.
If you have any questions about any of these items please ask. Pictures emailed upon request.
Thanks,
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 04-18-2010, 02:23 PM
65gto69's Avatar
Hi Guys,
1) A set of 4 1966 Pontiac rally 1 wheels with centers and after market original rings. This is an original set had them for over 20 years, mounted on tires. Great condition but do not know the code because of having tires mounted. SOLD
2) 1965 tri-power intake in great shape except when I purchased it someone welded the heat tube areas shut, other than that in really great shape and have used it about 20 years ago. I am missing the front carb due to a fire, but have the center and the rear., and 3 repo chrome air cleaners with paper elements. I am sure the welded tubed can be opened and put back to stock, I never worried about it never used the choke. SOLD
3) 1968 Pontiac 400 YC motor. This was pulled about 3 years ago and was running when pulled, I replaced with the motor in my signature. This motor was my pride and joy and has great power. Motor has 3.75 stroke arma steel crank, polished 58-62 forged rods, trw 30 over pistons, total seal gapless rings, clevite bearings, crane cam flat hydraulic 495/510 lift, 1968 #16 heads, have been ported and bowled flowed 250 at 600 lift, misplaced sheet, crane springs to match cam, stamp steel 1.65 rockers, polished torker 1 intake, R.A.R.E. 1967 Pontiac HO cast iron headers, chrome tall baffled valve covers, timing cover, water pump, pulleys, dist w/ accel hi-po points, condensor, cap & rotor and accel yellow superstock wires. Motor should be gone over because of sitting, stored in climate controlled garage since pulled. $2500.00 pick up only.
4) 1965 power brake booster and master cylinder, removed from car due to new motor, no room between valve covers and booster and not enough vacuum, worked great when pulled 1 year ago. $200.00 plus shipping or can pickup.
5) A pair of Cragar SS wheels, dated 1987, excellent condition, stored in garage for over 20 years. Wheels are 14x8 with dish in front. Wheels have original Cragar center caps. $200.00 plus shipping or can pickup.
Thanks,
Mark
Old 06-19-2010, 11:30 PM
65gto69's Avatar
Hi Guys,
3) 1968 Pontiac 400 YC motor. This was pulled a few years ago and was running when pulled, I replaced with the motor in my signature. This motor was my pride and joy and has great power. Motor has 3.75 stroke arma steel crank, polished 58-62 forged rods, trw 30 over pistons, total seal gapless rings, clevite bearings, crane cam flat hydraulic 495/510 lift, 1968 #16 heads, have been ported and bowled flowed 250 at 600 lift, misplaced sheet, crane springs to match cam, stamp steel 1.65 rockers, polished torker 1 intake, R.A.R.E. 1967 Pontiac HO cast iron headers, chrome tall baffled valve covers, timing cover, water pump, pulleys, dist w/ accel hi-po points, condensor, cap & rotor and accel yellow superstock wires. Motor should be gone over because of sitting, stored in climate controlled garage since pulled. $2500.00 pick up only. STILL AVAILABLE!
4) 1965 power brake booster and master cylinder, removed from car due to new motor, no room between valve covers and booster and not enough vacuum, worked great when pulled 1 year ago. $100.00 plus shipping or can pickup. STILL AVAILABLE!
5) A pair of Cragar SS wheels, dated 1987, excellent condition, stored in garage for over 20 years. Wheels are 14x8 with dish in front. Wheels have original Cragar center caps. $200.00 plus shipping or can pickup. SOLD!
Thanks,
Mark
Old 02-13-2011, 02:33 PM
65gto69's Avatar
UPDATE, All is sold except for the power bake booster and master cylinder.
Hi Guys,
3) 1968 Pontiac 400 YC motor. This was pulled a few years ago and was running when pulled, I replaced with the motor in my signature. This motor was my pride and joy and has great power. Motor has 3.75 stroke arma steel crank, polished 58-62 forged rods, trw 30 over pistons, total seal gapless rings, clevite bearings, crane cam flat hydraulic 495/510 lift, 1968 #16 heads, have been ported and bowled flowed 250 at 600 lift, misplaced sheet, crane springs to match cam, stamp steel 1.65 rockers, polished torker 1 intake, R.A.R.E. 1967 Pontiac HO cast iron headers, chrome tall baffled valve covers, timing cover, water pump, pulleys, dist w/ accel hi-po points, condensor, cap & rotor and accel yellow superstock wires. Motor should be gone over because of sitting, stored in climate controlled garage since pulled. $2500.00 pick up only. SOLD!!!
Thanks,
Mark
