Oil filter housing??
I have a Kauffman Racing Equipment block plate for my oil filter housing in order to run a remote filter setup.
Which port is for oil out from block and which is in from remote filter setup?? Thanks |
Oil pickup (from the oilpump) is on the bottom of Pontiac engines. Oil delivery is on the top. - Bill -
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk 1.35 w/29.5x10.5x15 6.42 @ 109 10.09 @ 133 |
Bill
Thanks alot. |
RED FLAG!!
We've seen significant oil pressure loss from using remote filters. Be certain ALL the lines and fittings are LARGER than the holes they're "feeding" or being "fed" by. Also, the filter should be as close to "level" with the inlet/outlet as possible. Lastly, DO NOT hang the filter "upside down" (I've seen it more than once...). Prime the oiling sytem or fill the filter during oil changes. Jim |
