Old 06-13-2009, 11:37 PM
Bl1tzw1ng Bl1tzw1ng is offline
Default What's this stuff worth?
Alright guys, I need some help. I have a few things off my 73 TA that I no longer need and I have a few people from PY interested. Usually, whats it worth threads are frowned upon but I could use the help.
Complete rear sway bar setup with bushings, drop links, shock plate sway bar brackets, and the sway bar, in great condition just the wrong color.
Sway bar brackets for the frame, good condition. Outter edge was cut level with the frame so they are about a 1/4 inch short on the outside, but welded right, would be correct looking. I do remember the ebay auction the ended over $300 for these about a year back. Was that a fluke?
Washer bottle or overflow bracket. Can't remember which this is as my car has been apart for a long, long time.
Battery cable tube.
I will post up pics tomorrow of the other stuff.
To be clear, I just want fair pricing so someone can get the parts they need and maybe I can use the money to get some I need.
Old 06-14-2009, 12:19 AM
mlubahn mlubahn is offline
Hello. I think they reproduce the rear sway bar brackets now. I saw a set on ebay a couple of weeks ago with a buy it now of 69.00 or so?
Old 06-14-2009, 12:10 PM
x-bird2 x-bird2 is offline
rad overflow bottle bracket and starter wiring tube. being chromed, you'll probably jsut want to take what you're offered for them.
Old 06-14-2009, 10:40 PM
Here's the frame mounts. The sides were cut kinda....not perfect as you can see.
Old 06-14-2009, 10:42 PM
Ok and here's the sway bar setup:
