Old 06-15-2009, 06:01 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Default 66 GP 4 sp shifter porch
MIne is all rotted out, can rebuild but if someone has one available let me know.
Do the Chev guys repro one? Will a GTO porch fit with some modification?
Old 06-15-2009, 07:56 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Keith, if this is any help.....parts book shows 65-68 P/8...cover...9780168. Fits "big car" only.
Grant
Old 06-15-2009, 08:08 PM
428ho4spd's Avatar
Maybe?..... http://forums.maxperformanceinc.com/...d.php?t=583665
Old 06-15-2009, 11:00 PM
crashent crashent is offline
Are you looking for the shifter mount(the piece that bolts to the tail housing that the shifter bolts to)??? Crash
Old 06-16-2009, 02:24 AM
No the hump that bolts to the floor.
Old 06-20-2009, 09:09 AM
goldeneyee goldeneyee is offline
Check with Les at Pontiac Paradise--He's about to market a reproduction...
Old 06-20-2009, 03:16 PM
Yes I'm on it. About a month or so away I guess, might buy two and bring to NOrwalk for all to see.
KEith
Old 07-17-2009, 08:20 PM
Still need this part, didn't find anything in Dayton. Have to install the carpet shortly, need one to do it!
KV
Old 12-28-2009, 11:08 PM
Rapdron's Avatar
Rapdron Rapdron is offline
Question 66 4 speed shifter porch
Keith
Have you found out any more information about a reproduction shifter porch?
The one in my 66 has a major rust spot/hole on the left side.
It could be repaired, but a new or decent used would be be great
I am just starting the restoration on my 66 Bonneville Convertible, but it will have to repaired/replaced eventually.
Thanks, Ron
Another Red Light Nightmare
1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw
1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project.
Semper Fi
Old 12-28-2009, 11:28 PM
Got the first repro one out of the mold, it wasn't the best. Hadn't used it, figured I would still look around or fix my heavily rusted piece.
KV
Old 01-02-2010, 02:20 PM
Rapdron's Avatar
Thumbs up Shift Porch
Keith
I just ordered a steel reproduction shift porch from Ames, part # R146B (Sorry Chris, PY didn't list one )
I should be able to cut the bad section from mine and weld in the new piece
Semper Fi
