i need some help here.holley 850 spread bore-worked fine all last year,today on a hard run let off and it stalled.got it started and it was flooding out.wont idle fuel runs out past the booster rings,took it apart blew every thing out,checked power valve was ok,put it back on same thing.tried another good power valve,same thing.why would it keep pulling fuel out the booster and flooding engine? this is driving me nuts,do metering blocks go bad? thanks for any help.bob
check float level, needle and seat for debris.
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph |
cked float,needle n seat-all is well.
Lower float level some and see if it stops.
Regardless what it "Looks" like replace the needle/seat, do a submerge test on the float, and replace the metering plate to mainbody gasket. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! ![]() |
i will try it tomorrow.i hate not seeing the problem. thanks
Check for bad fuel line from pump to tank. Rusted metal line sucking air or rotted rubber line at tank or plugged fuel sock in tank. Does the carb catch fire when you try to start it sometimes too?
carb works good 3/8ths throttle or more just wont idle because fuel is running out the booster rings.i did lower float adj some but it was already ok.
So fuel level is good, no gas pouring out of the sight plug?
Check all the air bleeds, blow them out with carb cleaner/air. Check metering block for signs of fuel weepage from port to port.
blew out bleeds,replaced gaskets,float is good,replaced needle n seat.put it together and still does the same thing.i can keep it running if hold the throttle open but gas just runs out the booster ring flooding it.what would make it start pulling fuel like that all the sudden?
