Old 07-10-2009, 09:11 AM
rad400 rad400 is offline
Default cam pricing ?
Looked at summit under cams they sell comp 292h cam .244/.244 @.50 .501/.501 lift for Chevy its sells for 109. For Pontiac same cam numbers etc. 139.00. So if I wanted this cam couldn't I tell then it for a chevy and get it for $109 vs. $139. this question is really based on price not so much for my combo.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 07-10-2009, 09:27 AM
67drake's Avatar
67drake 67drake is offline
I don't think a Chevy cam will fit your Pontiac engine. The lobe #'s are the same,but can't switch between two different type blocks.
‘55 Catalina
Old 07-10-2009, 02:07 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
a chevy is a chevy and a pontiac is a pontiac. chevy's are cheap, pontiacs are not!
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 07-10-2009, 06:51 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Volume, they produce and sell millions of "Chevy" cams but only thousands of "Pontiac" cams. Demand of each is priced accordingly. Some times the truth just hurts. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 07-11-2009, 11:07 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Chevy cam will NOT fit a Pontiac block. You just have to tough it out and pay more for the Pontiac part. Be thankful it isn't a Buick or Cadillac performance part...
