1978 Pontiac Firebird Trans Am.400 cubic inch engine TH350 auto trans.both professionally rebuilt with 1500 miles since the rebuild.Posi rear with 3:42 gears.True dual exhaust with headers and crossover pipe.BF Goodrich tires on 15x8 (WS-6) snowflake rims.Brewster Green with Tan interior.Very solid car,passed Texas inspection.Runs and drives like new.I spent over $12,000 so far to get it to where it is now asking $7000. A paint job will complete this very reliable driver.
Following is a list of what was done to this car by me 1.Milodon water pump 2.High flow 160 degree T'stat 3.Temp. sending unit 4.rebuilt Q-jet carb 5.Brake proportioning valve 6.Stainless braided brake lines 7.Stage 8 locking header bolts 8.speedometer cable 9.motor mounts 10.trans mount 11.Hotchkis front coil springs 12.PST super poly front end rebuilt kit 13.Timing cover 14.Aluminum valley pan 15.Engine wiring harness 16.Polygraphite subframe/body bushings 17.full size spare 18.Bilstein shocks(front only) 19.Rebuilt TH350 20.brake vacuum booster 21.Jet hot coated headers 22.Powder coated frame/control arms/spindles 23. front end alignment 24.rebuilt 72 400 new pistons,rings,gaskets,cam bearings,rod and main bearings,oil pump,lifters,timing set,cam,3 angle valve job,valve guides. 25.stainless full brake line set 26.stainless trans cooler lines 27.aluminum radiator 28.brake calipers 29.Stainless steel fastener kit.complete kit for 78 TA (Totally Stainless) 30.Grant removable steering wheel (I have stock wheel in excellent shape) 31.subframe connectors (bolt on)
Brakes? Who needs brakes,they'll just slow you down!! Last edited by dean7276; 07-10-2009 at 10:14 AM. Reason: Didn't list price |
Nice Car !!! Any interior pics ???
Here's a few.Can take more if you like.Interior is in good shape.As you can see there is no heater control,prev.owner took all heating components out.
Grant removable steering wheel is installed but I have the stock wheel which is in very good shape.
Brakes? Who needs brakes,they'll just slow you down!! |
Is the car a Firebird made into a TA or a real TA per the VIN? I ask because of the interior color set.
Jimmy www.firebirdgallery.com 2002 WS6 M6 Trans Am - original owner 1973 Trans Am 455/4-speed 1971 Formula 400/400 1969 GTO 400/400 - 3rd owner 1968 Firebird Convertible 350/200R4 POCI - AAC |
2W87Z8L148250
Thanks. Does the data plate list an interior trim code? I'm very surprised Green would have been available on a TA. I am interested in the car, just working out the particulars.
Bump!
Brewster Green is a one year only color that was put on 1973 Trans ams.
In the birdcage: 1972 T/A, White with blue Deluxe interior 1973 T/A Brewster Green with Saddle Deluxe interior 1977 SE T/A, Black with Black Deluxe interior 1981 SE Turbo T/A, Black with Deluxe Tan velour interior. 19,000 original miles. Owned since 1984. |
Re-painted somewhere in it's 31 year history.
What is the color code on the trim tag. It will tell what the original color of the car is.
Solar Gold w/Dark Camel Deluxe interior.
The car is sharp. Never seen one in green like that. Kind of cool. The gold was a great color too. Is it reliable? Need anything to cruise it around? Is it one of those "I'd drive it anywhere" type cars.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them. Check out my sons blog, www.driftundertheradar.com ![]() |
It runs like a champ.engine and trans are brand new.as is mostly everything else under the hood. Yea, I'd drive it anywhere.Only thing it lacks is A/C and heat.
End of summer sale! $6250 drives it away!
