Old 07-12-2009, 09:31 AM
Pontiac Iron Pontiac Iron is offline
Default 1973 Grand Am Parting Out
Parting out a 1973 Grand Am 2-door coupe with a XJ 455 and turbo 400 trans.Car is rough but complete.If someone needs a part,let me know and i will check condition.
Old 07-13-2009, 02:23 PM
Price?
former." --Albert Einstein
- Winston Churchill
Old 07-13-2009, 06:32 PM
Price for the entire car $1,300.00.
Old 07-14-2009, 07:35 AM
86t-type 86t-type is offline
Sent a PM
Old 07-22-2009, 01:47 PM
I will have the car for one more week before going to the crusher.If anyone needs anything else,let me know.
Old 07-22-2009, 02:13 PM
PMDJIM's Avatar
PMDJIM PMDJIM is offline
how much for the steering wheel and cap. condition?
Old 07-22-2009, 02:50 PM
The wheel is decent with no foam missing around the rim,but the foam is cracked from age.How is $75.00 plus shipping.
Old 07-29-2009, 12:19 PM
The car has been stripped.Some of the parts i have are as follows.Steering wheel 75.00,windshield washer reservoir and mounting bracket does not leak 30.00,radiator overflow reservoir does not leak 30.00,A/C compressor and all mounting brackets 75.00,Complete outer A/C box assembly,nice shape with no cracks or breaks 125.00,rear sway bar 90.00,wiper motor tested and works fine 30.00,front windshield trim 35.00,rear window trim 35.00,Grand Am emblems 35.00,driver side grille 30.00.
Old 07-30-2009, 12:55 PM
73and74GA 73and74GA is offline
Default I need a few things
Plastic trim pieces with no sun damage or deterioration that fit over the screws that hold the door panel pull straps on (2 of those pieces per door panel).
Excellent used rear taillights.
Unique screws and screw anchors that hold on the metal fuse cover plate that is found below the steering column. I have the metal plate but not the screws and anchors.
Drivers side front grill.
Interior rear plastic sail panel pieces with no sun damage or deterioration. Interior plastic trim pieces around windshield and rear window with no sun damage or deterioration.
Old 07-31-2009, 08:40 AM
I have the driver side grille with no breaks for $30.00 plus shipping.I have the two door pull straps with three nice plastic trim covers.The forth cover is missing.$25.00 plus shipping.I do not want to break the door pull straps up.The interior trim has already been sold.
Old 08-15-2009, 09:45 AM
I still have a good amount of parts from the 73 Grand Am if anybody needs anything.
Old 08-20-2009, 08:11 AM
Mike1975 Mike1975 is offline
What is the condition and price for the rocker trim and hardware?
Old 08-20-2009, 10:10 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
I dont suppose the 455/400 is still around, is it?
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 08-20-2009, 10:14 AM
The rocker trim and headlamp bezels were sold weeks ago.
Old 08-20-2009, 10:16 AM
The 455 out of the grand Am is long gone.I did pick up a 455 code WX with 6H heads out of a 76 T/A.It is apart.$600.00 if you are interested.
Old 09-10-2009, 01:25 PM
I still have a good amount of parts for sale including the automatic console and shifter for $80.00,engine mount brackets $35.00,gauges $40.00 plus many other pieces.
Old 10-13-2009, 01:58 PM
I still have some parts left.
Old 10-15-2009, 07:09 AM
rickw rickw is offline
I'm in need of a good upper drivers door hinge
Old 10-15-2009, 07:48 AM
Sorry,the door hinges went with the car to the crusher.
Old 10-29-2009, 09:23 AM
The grille is sold.
