Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Closed Thread
Old 08-01-2009, 10:50 AM
78 GHOST 78 GHOST is offline
Default Anyone considering a RobbMC starter.
Working on my 1970 GTO. This car is pretty much all new from the paint, to the wiring harnesses, to the ground straps, battery cables, battery (Optima style NAPA), and a special high torque rebuild of the original starter.. dreaded hot start issues.
Finally threw in the towel on the OEM starter and bought a RobbMc starter.
Wired it up with a Ford remote solenoid to use as a relay for the "S" wire only, and as a wire junction to ease starter installation.
Adjusted to spec, and voila' this 473 starts like never before. If you're tired of wondering if it will start, you need this starter.
I couldn't be happier with the product and customer service.
-Matt
____________________________________
"I work in high speed aluminum tubing."
Closed Thread
Smilies are Off
