Old 08-03-2009, 06:17 PM
BRYN-THOMAS's Avatar
BRYN-THOMAS BRYN-THOMAS is offline
Default Boost and air/fuel
Hi guys
Would increasing boost (roots) by a couple of lbs make a diffrence to air/fuel ratio.
Had car on chassis dyno all good 440hp at wheels uncorrected at 5lb boost so got room to play.
Three good runs last sunday 10.75 10.74 10.78 at 124 60ft down from 1.8s to high 1.5s mickey thompson sportsman pros seem to work at 9-10lbs
cheers
Old 08-03-2009, 08:00 PM
Technically, no or depends.
What do you have for an induction system?
Old 08-03-2009, 08:43 PM
ponchospidel's Avatar
ponchospidel ponchospidel is offline
to be safe, you should jet it up if you are going to increase boost levels.
then lean it out afterwards.
1973 ventura pump gas street car [email protected]/ [email protected], 3645#
1968 procharged firebird 5.66@123mph 1/8mile-F-2(22#boost), CSU E-85 carb, 477 IA2, 315cfm Butler E-heads, and factory suspension, 3580#. 939RWHP@25#boost
thanks to Butler Performance, CSU carbs, and All Pontiac.
Old 08-03-2009, 10:15 PM
Tom Vaught's Avatar
Boost Engineer
1) Buy a good air/fuel wide band ego sensor system.
2) Start rich, as was said, 11.5 and slowly move toward 12.2
You want the a/f to be a flat line at all rpm points under wot.
Tom Vaught
Old 08-04-2009, 11:20 AM
baron_ baron_ is offline
Send a message via AIM to baron_
indeed on wideband
lm1 with XD gauge is quite nice
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 08-04-2009, 11:41 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Curious where is the best place for the a/f sensor ?
Old 08-04-2009, 11:45 AM
best to have a heat sink or something...or bung extender
and put it 18" to two foot? past the turbos...so it doesn't overheat
The closer you go to the turbo, better chance of an error or overheating the sensor....
But needs to be in front the end of the exhaust at least a foot maybe two (or you'll read some of the reversion, on occasion)
And there's a whole discussion regarding the angle of the actual sensor, so it doesn't collect condensation
Clay Marsh
Old 08-04-2009, 11:48 AM
GTOGreg's Avatar
GTOGreg GTOGreg is offline
I put mine at 9 o'clock (LH) and 3 o'clock (RH) about a foot past the elbow on the downpipes coming from my manifolds. You don't want them below this as condensation will shock the O2 sensors and ruin them quickly. 10 and 2 o'clock would be even better - somewhere in the top 180* of the pipe. Keep you wire run to the firewall in mind.
Wideband is a GREAT investment for peace of mind with your AFRs. You 'll want to wire your meter to the tach at a minium. Then, depending on your meter you can measure/map/monitor intake air temps, EGT, manifold air pressure, etc...(if desired) . I bought the LM2 from Innovate and it was the best $350 I've spent to date.
1967 GTO
Tyrol Blue/Blk Cordova
400, TKO-600, 8.2 Posi w/3.55
400 + .020, decked to .005
SD Performance 240+CFM 670 heads
RARE HO/RA manifolds
RARE 2.5" Exhaust (18" Magnaflows)
SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL)
PRW stainless 1.52 roller rockers
Forged TRW slugs
SCAT H-Beam forged rods
Old 08-04-2009, 04:41 PM
2 750 Mighty demon blower carbs 8/71 stage 2 bds blower and intake ported 87cc e heads, 15% underdriven.
was thinking of fitting some sort of data logger to get a/f, boost, rpm, any suggestions?
thanks
Old 08-04-2009, 05:59 PM
Tom Vaught's Avatar
Boost Engineer
Check out this forum:
http://www.innovatemotorsports.com/f...isplay.php?f=3
They have good air fuel meters but what is even better a forum to discuss all parts of the system and the data logging.
Unit can log several things and display on a laptop easily.
Tom Vaught
Old 08-04-2009, 06:14 PM
Thanks Tom exactly what i wanted
Old 08-04-2009, 06:51 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
Talking
Thats what I did on my roots blown boat motor. I ended up back where I started at jet wise. Must be OK-It hasn't melted down yet (50ish hours since the boost increase) I only have plug readings and an EGT to go by, no wideband 02 sensor.
Old 08-04-2009, 09:19 PM
Tom Vaught's Avatar
Boost Engineer
So Mr Twister, what was the original Boost Level vs the increased Boost Level of your boat engine?
Boat Engines typically run cool so they can be leaner vs a car engine and Carbs typically have a pretty wide range of Air/Fuel ratio vs the speed load.
Carbs can actually add more fuel with the same main jet size depending on signal to the jet.
Tom Vaught
Old 08-04-2009, 11:14 PM
Torment's Avatar
Torment Torment is offline
I'd insure you found the optimum jet for the current drive % if you haven't already. I varied my OD % a good deal from street to strip driving - but the jet was setup for best performance with the greater OD in good air.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 08-05-2009, 07:41 AM
Mr Twister's Avatar
Tom Vaught
5.5 no intercooler, to 6.5 BELOW the intercooler installed at the same time. I think you lose 1 pound of boost due to the intercooler on this application. The engine does run a steady 155 deg. I havent run a roots blower on a car, so this may not be apples to apples.
