Old 08-16-2009, 07:45 PM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
Default 1967 Pontiac firebird bracket car
1967 Pontiac firebird factory Madeira Maroon All steel except hood car weighs 3150Lbs.
Chassis cert 850 and slower Apr.09 good until Apr.2012 Factory frame with sub frame connectors
New Belts Apr 09
410 spool with C-clip eliminators
Front disc rear drums
Weld Racing wheels
Hoosier rear tires new Feb 09 12-1100-15s
Hoosier front tires
Factory dash with heater control delete for the Auto meter gauges (volt water and oil) Tach on dash
Front and mid motor plates
Holley black pump with Fram canister fuel filter
New factory gas tank with sump install Mar. 09
1974 400 4.155 bore and 4250 stroke (461 stroker motor)
Billet 4 bolt Main caps with ARP stud kit used for entire motor
Mega lifter bore brace
KRE 56cc wide port heads with Ferra valves and titanium retainers
Comp roller cam INT .660 EXT. 661 lift
Manley 3/8 x 10.200 push rods
Crower roller lifters
Crower 6.800 forged rods with SRP flat top pistons
Ohio forged crank
ATI balancer new Mar 09
Meziere water pump
Victor intake with Quick Fuel Carb 4150 1050
Perma cool oil filter with Wix 51222r 1 qt oil filter
MSD Pro Billet distributor with Taylor 10.4 mm Wires
MSD 6al 2 step ignition
Turbo 400 trans with reverse valve body and B&M ratchet shifter.
The paint on the car has some chips and scrapes from racing But over all in very good shape
The car runs 10.0s all day long with 1.40 60ft. Times at 131 mph though the traps personal best was 9,99 The car leaves hard and straight and is fun to drive.
Turn Key $15,500.00
Roller $6500.00 comes with driveshaft Headers both front and Mid Plates
ID:	178313   Click image for larger version
ID:	178314   Click image for larger version
Old 08-16-2009, 08:11 PM
KEVGTO KEVGTO is offline
pm, sent
Old 08-17-2009, 07:09 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
I miss that car, hope it gets a good home!
66 GTO
Old 08-22-2009, 07:35 AM
more pictures
Name:	firebird motor.jpg
ID:	178905   Click image for larger version
Old 08-22-2009, 09:49 AM
Region Warrior's Avatar
Thought that car looked familiar.
Good price, but wrong time for me.
Old 08-26-2009, 06:40 AM
Roller sale pending Motor still available
